Rib case problem
atlaajetmech
I ran my 74 Midget transmission a little low on oil. After topping it off it is making a intermittent loud snapping sound when in gear and foot off the throttle.
It sounds normal when under load only makes the noise when I back off. I know it is a pull out an tear down. Just want to get a little ready for what to
expect when I take it apart.
LarryK
Could be sychronizers or the little bearings in the gears moving around. Change the oil first and see if it is still there.
A
atlaajetmech
Thanks Larry, The syncros are good as I have been babying them. I can’t believe I let oil get
so low. I will try the oil change.
BlueMax
That would be Ok with a conventional gear box with a roller release bearing but, being that the Sridget clutch release bearings are carbon every time you engage the clutch peddle only wears the carbon off faster. So your actually working the bearing double time by doing so unless your racing and pull engine frequently to replace it?
A
atlaajetmech
Well l would rather change a clutch than tear down a gearbox.
I raced HP years ago and have had a bunch street sprites and midgets as well. Never noticed any unusual release bearing wear from double clutching.
Joe Schlosser
Same here, I never had to replace a release bearing either in my Street BE which was my daily for about 10 years or my FP car. Maybe the newer release bearing face material is softer than it was years ago.
Tim Hollister Rib Case Trans Problem - 1st Gear Spridgets 6
R RIB CASE SHIFT LEVER Spridgets 0
R Rib Case rebuild... Spridgets 5
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
A Wanted Rib Case Transmission Spridgets Classified 1
B Purchasing Rib Case Spridgets 17
Gerard Source for front cover w/seal for rib case Spridgets 15
jlaird Rib Case arrived Spridgets 13
britndablood FS 1098 with rib case in North Carolina Spridgets 0
drooartz Smooth case remote shifter on a rib case Spridgets 7
58Custom What is the best documentaton of rib case rebuild? Spridgets 12
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
S TR2/3/3A 1961 tr3 conversable top rib color Triumph 7
EVSpriteGuy Where to get a reman 1275 rib-cage tranny? Spridgets 15
sim Looking for a good usable rib tranny for 58 948 Spridgets 6
R Value of rebuilt 1275 Engine, new clutch & rib trn Spridgets 6
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
John Turney Getting Speedometer out of the Case Austin Healey 6
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
F Ribbed case tranny in 948 bugeye Spridgets 2
F Wanted Smooth case trnny Spridgets Classified 6
6 Spridget Radio/Speaker Case Spridgets 4
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
C TR2/3/3A Transmission case ID Triumph 3
B Tar case glass mat batteries Austin Healey 8
mailbox General MG In case anyone needs a project or parts MG 0
Rhodyspit75 General TR Just in case you're not on my Christmas card list. Triumph 3
M Smooth case front cover Spridgets 9
T Basket case BJ8 values Austin Healey 10
NutmegCT In case you need one - Other Cars 1
M Smooth case gearbox in early MKII Sprite? Spridgets 23
apbos Awakening the Smooth Case Transmission Spridgets 7
I Smooth case transmission help please Spridgets 11
M crank case vent pipe Austin Healey 11
rkep01 Question about front cover on smooth case trans Spridgets 5
L How to repair cast aluminum transmission case Spridgets 26
K TR2/3/3A TR3A...Tighten Diff Case Bolts? Triumph 5
tahoe healey Ken's case Austin Healey 1
HerronScott Alternator in generator case project? Triumph 2
TexasSprite Tach Case Interior Colors MG 3
TexasSprite Tach Case Interior Colors Spridgets 12
M Seeking 3.9 or 3.7 diff case or just gears Spridgets 3
B TR2/3/3A 57 TR3 Newbie...No spark? Basket case Triumph 31
bgbassplyr In case you missed British Motor Corp 1
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
