TR2/3/3A Fuel bubbling at glass filter bowl
HighAltitudeTR3
So I went for a cruise today and the car is running great, I have never noticed this before and I’m not sure it’s normal (although it doesn’t seem normal).
I have bubbling in my glass fuel bowl (filter removed for inline filter). It’s hard to say what’s causing this...
TexasKnucklehead
I don't know at that elevation, but here in my garage (at about 30') (and regular 'summer' blend pump gas) I measured mine boiling at 135 degrees.
My fuel filter is in-line nearer the SUs, but glass. It bothered me that the fuel filter would appear empty after a drive in temperatures over 95. After the car sits for a while, the fuel would start to bubble back in. Mind you, the car ran fine, wasn't overheating or having percolation/vapor-lock issues but the clear filter always appeared empty when I got home.
One day I attached a temperature probe to the filter and drove the car until I could see no fuel. Then I came back home and measured the temperature of the filter housing, and waited/watched until it cooled enough to bubble back into the filter (appearing to fill it up), then I waited/watched until it stopped bubbling. It stopped bubbling (boiling) and remained liquid/visible at 135. -I watched a video where a guy heated a quart of pump gas until it boiled with a flame, and decided there had to be a safer way to measure that.
It had nothing to do with the problem I thought I was having at the time, but it was interesting. If/when your electric/aux radiator fan turns on, it will move 180+ degree air onto the fuel line...
XK4
What I saw in the video wasn't the fuel boiling. It was what it looks like when fuel is added to the glass bowl.
When the engine is running, fuel does not flow into the carburetor in a steady, continuous flow. Rather, it only flows when the float in the carburetor drops and opens the float chamber valve. Very similar to the toilet tank valve setup.
I don't know if you've looked into a toilet tank recently but if you do and you carefully let some of the water out of it by pulling up very slightly on the drain valve the water level will start to drop.
It can drop quite a long way before the inlet valve starts adding water to the tank.
The same thing happens in your carburetor. The float chamber has enough fuel in it to keep the inlet valve shut. As the engine runs, the fuel level drops to a lower float position which will open the valve.
When it does, the fuel pump will start pumping a little fuel thru the glass bowl your looking at and you will see the "bubbling".
When the fuel level in the carburetor raises enough, the float chamber valve will close the inlet valve and the fuel pump pressure will increase to the point that it stops pumping fuel. That's when the "bubbling" in the glass bowl will stop.
There is not a lot of difference between the levels of fuel in the carburetor float chamber between the open valve and the closed valve conditions. That's why the "bubbling" occurs for a few seconds and then stops for a few seconds and then starts again.
You probably already know this but that glass bowl is there to collect any water that has been pumped from your fuel tank.
Water, being heavier than fuel will sink to the bottom of the bowl, preventing it from reaching the carburetor and causing mischief.
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
P XJ12 Fuel pump relay 85 Jaguar 4
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
