TR2/3/3A tr3 temp guage capillary tube thread size
Dave L
does anybody out there know the thread size for a tr3 water temp capillary tube thread where it goes into the t stat housing. I am trying to block off the hole so I can run my engine without the gauge for now? I read it was 5/8 but that seems to large.
Thanks to all,
Dave
martx-5
It's not a pipe thread. It's a 5/8"-18 NF thread. The bulb on the capillary tube seats inside the housing. That is what prevents water from getting past the threads. You might be able to get away with a 3/8"-18 NPT plug. I measured one, and the bottom is a little larger than 5/8", so I don't know how far it would thread in. I would be very careful trying to use one of those. If your old gauge is shot and you want to send it out to get repaired, why not just cut the capillary tube a couple of inches from the fitting and just screw the bulb and fitting in.
Geo Hahn
I haven't tried it but would think a sender from a TR4 would make an okay plug (if you can lay hands on one).
But depending on what you want to do with the engine with the gauge out you might get away with a rubber plug and leaving the radiator cap off.
I once stuffed an ear plug into the metal heater pipe (threads to the valve failed) and duct-taped it in place. Drove home like that with no problemo.
TR3driver
Great Pumpkin - R.I.P
Yes, the TR4 sender fits fine (I have one in my TR3).
Another alternative might be to just buy a cheap mechanical temp gauge. I don't know if the electrical ones come with the same thread; but every mechanical gauge I've seen uses the same fitting as TR3; even when the package says otherwise!
Sorry, I have absolutely no idea of what the application was. But years ago, I was trying to get a TR3 home by driving it; when the Tstat housing fell apart. I carried the remains into a nearby FLAPS and scouted through the water outlets until I found one with the same bolt spacing. Of course not the same size & shape, and no room for a thermostat (or bypass fitting); but by adding a long flexible hose, it worked for 1500 miles or so. ISTR I used a sparkplug & hose clamp to close off the bypass hose.
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
G TR2/3/3A TR3 Temp gauge Triumph 2
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
6 TR2/3/3A electric coolant temp gauge in TR3... Triumph 6
tinman58 TR2/3/3A TR3 temp gauge Triumph 13
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
T TR2/3/3A TR3/4 elec. temp gauge Triumph 6
Perrymip TR2/3/3A TR3 Sudden Temp Jump Triumph 7
C TR2/3/3A TR3 temp sensor hole plug? Triumph 4
K TR2/3/3A TR3 Temp Gauge Upgrade? Triumph 5
K TR2/3/3A Reliability of TR3 Temp Gauge? Triumph 16
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
TRclassic3 TR2/3/3A TR3 temp gauge Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
M TR2/3/3A TR3 Temp Gauge Triumph 27
F TR2/3/3A TR3 Seats and Temp Gauge Triumph 5
