Engine in or out
barnman
Hi All, thanks for recent advice re paint codes etc.
Chassis and underbody now painted and ready to go with oily and not so oily bits.
We have trial fitted shrouds and panels re door gaps and swages etc along with hood frame.
We have carried this out with no loading from the engine and gearbox...ie they are out.
Any views on whether to preload prior to next panel fit or will it not alter much in view of new chassis/sills/floors etc.
I have seen images where weights have been placed in the gearbox area to ? simulate loading here.
Any further input appreciated.
Thanks Al
Healey Nut
My opinion is if your chassis flexes that much with driveline weight that it affects the panel fit then you need a new superstructure or the existing superstructure was not repaired correctly .
Keoke
Alwys preload with
the engine and gear box
prior to final Panel fit
red57
I tend to agree with Healey Nut. I know I hear about folks talking about how important installing the 650# of the engine & tranny is, but why have I never heard of anyone adding 3-400# where the seats are to simulate driver & passenger??? If my chassis flexed that much, I expect the doors would be popping open when crossing a RR track, not to mention rubbing the paint off the door edges. So I personally doubt the need, but freely admit I could be wrong too...
Dave
CLEAH
I agree with Dave and Healey Nut. The weight of the engine and transmission is distributed over three mounts, two of which are over the front wheels. At most the weight at the transmission mount is 250 pounds. That is not going to measurably flex a solid chassis assembly. Concerned about this myself, when I disassembled my car to begin its restoration, I measured the door openings with the drivetrain in place, then again once the drivetrain was removed. No change in the measurements. My car was completed by a professional restoration shop that fits panels without the drivetrain in place.
B
barnman
Thanks for that.
The chassis is brand new as are the floors sills etc.
Also fully seam welded so cannot get much stiffer/stronger.
I take the point also about the weight over the front wheels.
Regards Al
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 4
L Engine ID British Motor Corp 2
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
J Engine Parts Suppliers Austin Healey 6
J TR2/3/3A Engine mount Triumph 5
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
