TR2/3/3A Pressed steel body plates??????
kjman55
I just found an EB plate and body plate I removed from a long door 2 ( around TS3500 ish from memory) back in 1975. It was in a box of stuff lost/ misplaced for over 40 years. What was odd was that these plates were made in pressed steel, not brass. The numbers were correct for the commission number and date of the car (June 54) and they were identical to the usual brass plates in every respect other than the material. They were sprayed body colour--olive yellow-kak colour correct for that 1954 car, which was very rough but 100% original (with the rare red and black houndstooth trim.)
Has anyone else ever encountered steel EB and body plates? The car is long gone but I am intrigued by the plates...
Geo Hahn
Interesting - certainly the early cars had some differences and it is plausible that some of them have not been well-documented. Next time I see a friend's long door I may ask to test his plates with a magnet.
ckeithjordan
kjman,
I’d love to see a photo of the plates with the olive-yellow color. Thanks!
Keith Jordan
1957 TR3 TS20447LO
K
kjman55
Keith,
i will get them on the weekend and then try to figure out how to post a photo.I am new to this forum but no doubt there is a sticky somewhere on how to post photos.
Keith Manion
TS166
K
kjman55
Hi Geo
Not a bad idea...maybe the factory ran out of brass one day?
I have only ever seen or heard of brass plates on 2/3/3A/3B cars before discovering these ones. I bought the car for $150 in 1975 just for the houndstooth trim which was perfect, and gave the rest of the car to my brother as his 21st birthday present, which he restored on a shoestring while at Uni. The plates got lost under our parents house and came to light a week ago, and I just made the discovery when cleaning the paint off them. There was no (apparent) reason why they would have been fakes, and the stamping and size is 100% identical to the usual brass plates... A mystery.
2long
FWIW, the last olive yellow car was TS 1911 LO, so a TR2 with Comm #3500ish would not be that color originally.
Dan
ckeithjordan
Keith,
Posting images. At the bottom of the page where this thread appears, there's a "quick reply" box. At the top of the box are several icons, the third from right is one that is used to "insert image" (you may have to hover over it to see the pop-up description as I don't find the icon image to be intuitive). Use that to post a picture, following the prompts.
K
kjman55
Thanks for those directions, Keith.
Thanks 2Long. Now you have got me wondering...I always assumed the commission plate was right, maybe it was an identity swap and maybe the plates are dodgy. If fake, someone had an embossing machine / stamps the same as the factory, but not bright enough to use brass. None of it adds up!
F TR6 Idle change when brake is pressed Triumph 4
S worm gear pressed off Triumph 18
R Rock stands pressed on? Austin Healey 7
G T-Series MG TD Brake drums .. Bearings pressed in? MG 5
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
T Trying to identify a steel plate part Austin Healey 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
busybrit TR4/4A Steel dashboard color Triumph 1
JimLaney How to treat media blasted steel Spridgets 3
B ISO two[2] steel road wheels, Morgan Other British Cars 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
T TR2/3/3A TR3 steel wheels Triumph 6
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
simon1966 The jigsaw puzzle in Aluminium and Steel Commences. Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
D TR2/3/3A Tubes in steel wheels? Triumph 15
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J TR2/3/3A TR-3 Steel Wheel Repair Triumph 3
M Front steel brake lines Spridgets 9
BillyB62 TR2/3/3A Factory steel hardtop Triumph 14
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
J General Tech Stainless-steel caliper pistons Triumph 8
P Steel Wheels for a BJ8 Austin Healey 14
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
