Results 1 to 15 of 15
Thread: Custom Header IMSA TR8
  1. #1
    Jedi Warrior MadMarx's Avatar
    Join Date
    Feb 2007
    Location
    Germany, Saarbruecken
    Posts
    530
    Thanks Thanks Given
    2
    Thanks Thanks Received
    8
    Thanked in
    I found nothing right....so need to build that ****ed thing myself:
    To boldly go, where no man has gone before....
    http://www.tr4-racing.de/eng/madmarx-racing.html
  2. #2
    Great Pumpkin DNK's Avatar
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,539
    Thanks Thanks Given
    1
    6
    Thanked in
    Re: Custom Header IMSA TR8
    Wish I had your skills
    Don
    "Stick a Wedge in it!"
    Mount Pleasant,SC
  3. #3
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    ehm....the skills named saw, chuck, hammer, and a welding machine.
    My part on it is minor.
  4. #4
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    It has started with this:
  5. #5
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,087
    Thanks Thanks Given
    14
    61
    Thanked in
    That looks like a challenge. Great job.
    I have seen somewhere on the Net someone using a similar approach but they had custom dummy pipe forms. Probable not just doing a one off.
    David
  6. #6
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Why throwing money on stuff which you trash afterwards? These plastic tubes are cheap and doing well for getting an idea where to go.
    And I can reuse them for the other side header.
  7. #7
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,876
    Thanks Thanks Given
    3
    Thanked in
    Very impressive Christian!
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
  8. #8
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Todays work, make everything fit:
    Now working on the right hand side header.
  9. #9
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Ready to go:
  10. #10
    Jedi Knight TRMark's Avatar
    Join Date
    Apr 2003
    Location
    Billings, MT
    Posts
    1,335
    Thanks Thanks Given
    7
    5
    Thanked in
    Well then, lets hear it!
    ex spec5 Mark
    63 TR4 Surrey
    50's Cooper Alfa Sports/Racer
  11. #11
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Seems I'm running into bigger trouble:
    I'm not happy.
    Yesterday evening I had filled up the cooling system.
    Today morning I found the coolant tank empty.
    I've filled it up again (3L) and I saw a small leak on the left engine side where the chain housing meets the block.
    I tried to block the leak with silicone and left it like this for the day.
    This evening the coolant tank was empty again but no puddle of water on the floor.
    Tomorrow I'll open the drain plug of the oil pan and see if there comes any water out.
    Maybe the system leaks to the inside.
    Not good engineered engine to have water and oil side by side, just seperated by a simple paper gasket.
  12. #12
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    finally:
    BTW....I'm not fat...I'm wearing 3 jackets.
  13. #13
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Dyno Run:
  14. #14
    Join Date
    Apr 2003
    Location
    Billings, MT
    Posts
    1,335
    Thanks Thanks Given
    7
    5
    Thanked in
    Sounds like it will get out of its own way. What are the numbers?
    ex spec5 Mark
    63 TR4 Surrey
  15. #15
    Join Date
    Feb 2007
    Location
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    365 hp (at first) and 495Nm.
    Hp will get more soon. I need to make changes to my new exhaust.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
