Trying to find an accurate tyre pressure gauge
twas_brillig
I found a thread under the 'Restoration and Tools' forum entitled 'tire pressure gauge accuracy' started in 2016 but the forum doesn't appear really active so figured I'd follow up here. I've got probably half a dozen tire gauges, and they all read differently. I'd like to buy a couple of gauges (Christmas is coming) that specify their accuracy: I think I'm running our street legal Meyers Manx dune buggy clone fronts at 18 psi; but the gauges I own imply it could be 15 through 21 psi.
Michelin sells their MN-12279 and advertises that "Gauge accuracy is +/- 1% plus 0.5 PSI ". I figure 1% of 30 psi is .3 psi so they're claiming an accuracy of +/- .8 psi. Snapon advertises 1% accuracy for all their gauges (.3 psi at 30 psi), but I'm bothered that it's the same claim for the entire assortment: stick, digital, dial.
Andy suggestions as to suppliers that specify an accuracy? Thanks, Doug
nomad
Good ole Milton brand. Been around forever and USA made unless they have been gobbled up recently by a holding company and shipped offshore like nearly every thing. Don't know if they are precisely accurate but they are pretty much indestructible.
Kurt.
T
twas_brillig
https://www.leevalley.com/en/garden/page.aspx?cat=2,42194,76255&p=76104
I just picked up several of the 'cheap' version and one of the 'less cheap', as I was concerned that the 'cheap' ones might have trouble reaching the tire stems in a few cases.
I've only found Snap-On and a Michelin gauge that claimed a specific accuracy; these tyre gauges are less costly and claim +/- 1% accuracy. I haven't opened them as they'll be stocking stuffers for Christmas so haven't done a comparison, but have my fingers crossed. Doug
Healeysince59
The accuracy they quote is relative to full range. If full range is 0 to 100psi and the accuracy is +/- 1%, the accuracy is +/- 1 psi over the full range.
Marv J
T
twas_brillig
They have the same +/- 1% standard for both the 100 psi and the 150 psi gauge. I'm assuming that the +/- 1% applies to the specific pressure (i.e. 30 psi means +/0 .3 psi) being measured. If it was measured only at the full pressure, then presumably (me presuming) then they'd specify +/- 1 psi for the one gauge, or +/- 1.5 psi for the 150 psi max. Notice all the 'presumes' in here. Come post Christmas, I'll borrow a couple of them back and do some comparisons. Doug
leecreek
The accuracy they quote is relative to full range. If full range is 0 to 100psi and the accuracy is +/- 1%, the accuracy is +/- 1 psi over the full range. Marv J
True in my experience. That's why you don't want to use larger ranges than you need.
T
twas_brillig
Finally smartened up and dropped Milton a note last week, asking about their accuracy. I'll report back if/when I get a reply. And they do identify if the tire gauge was manufactured in the USA (found one; the rest I looked at were off-shored); couldn't find any accuracy info though. Doug
Joe Schlosser
I am a little confused with this. LBCs are not NASCAR or F1 and the majority of us do not put our cars on the track. What is the concern with tire pressure accuracy. How much does it matter if we are at 25psi or 25.5 psi.
T
twas_brillig
I'm not concerned about 0.5 psi; I am concerned over several psi. Plus, we all have our weird little interests (i.e.: hangups). Doug
glemon
I understand the hang ups thing, but still would say my bigger concern would be consistency, same reading on multiple attempts even if a pound or two off, so that even if your two fronts are at 30 lbs instead of 32 at least they are at the same pressure.
I have several guages. A few years ago a buddy who likes to spend money more than me (if I only hung out with people as cheap as me I wouldn't have any friends) made fun of my cheap "stick" gauge, afterwards I decided to check them against each other, all within a pound. Ranging from real cheap to kinda cheap, and one digital. I don't trust the digital gauges as much as a well built purely mechanical. My own little quirk I guess.
I would also add that the gauges seem to vary more depending on how firm and perpindicular your push on the stem is than the gauges themselves.
Stan Kowznofski
I agree that a pound or two higher or lower isn't a big deal as long as they are consistent. Air pressure is just a suggestion, suspension settings, driving style, vehicle loading, etc. varies by driver and no 2 are the same. I pay more attention to tread depth over the long run as the most important concern for street use is even wear. As long as the tread wears evenly you are making the best use of the entire tire which I think is the most important aspect of proper inflation.
SD Bugeye
First stop using air and fill with nitrogen if your trying for accuracy
T
twas_brillig
Just an update regards my note to Milton: never did hear back as to which (if any) are manufactured offshore or USA; never heard back as to their accuracy. Doug
nomad
Googled Milton and they are pretty proud of being made in the USA. All I know about them is that they have been making tire tools for all my adult life. I always liked them and go out of the way to buy Milton.
Kurt
T
twas_brillig
Bill - had a look at your jbtools web-site michelin gauge, and it's the same one that I'd found earlier in this process: "Gauge accuracy is +/- 1% plus 0.5 PSI"
I'm not too hung-up on our LBCs as I can find recomendations for tire pressures and figure that the recommendations (as well as the gauges) are somewhat 'more or less' as there are a lot of factors in determining 'best'.
My primary concern is our dune buggy - those 7" rims and tires are sure a lot wider than the original VW 4J x 15 rims 5.60 bias ply. Life is too short and mileage per year too low for me to figure out what pressures should be, based on tire wear. I'd done some testing using a hardware sourced laser temperature reader to measure temperatures across the tire tread and varying pressures as I drive down the highway. I also borrowed a tyre pyrometer from a racing buddy and did the same - in both cases, I did not get meaningful results. This could be a function of the stiffness of the radial belt and sidewalls, but I'm buffaloed as there should have been a measurable difference in temperature across the tire tread (3 measurements; centre and outer). I'll try again when the flowers bloom again next year, and move my outside measurement in an inch and maybe I'll get some info that way. Whether or not my tyre gauge was accurate for these tests wasn't as relevant as being repeatable - as pointed out by others.
However, I'd like to have an accurate result so that if I learn something and report it, then the tire pressure results will be meaningful.
And I'm gong to try the samething with our 3000; not sure if the wee 165s (?) that we have on the Yellow BE are wide enough to have a temperature differential....
Later, Doug
D T-Series Trying to find out an interior dimension MG 7
tomshobby I am trying to find the past history of my Midget. Spridgets 3
H AH 3000 Trying to find the right look Austin Healey 23
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
G Trying to Find T-Shirts Triumph 7
M Trying to Find a Family Heirloom Triumph 59
Earl Trying to find a part Triumph 3
A Trying to Find Healey Art Print Austin Healey 6
D Trying to get back working on the 1974 Midget Spridgets 7
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
Trevor Jessie Trying out a camera mount... Spridgets 20
