TR2/3/3A how to question for overdrive
Dr_Mike
Drained the oil (after 25 years laid up) and would like to take out the strainer and magnets (if any). I have to do this at arms length with only jack stand clearance. Is the pump going to fall out when i undo the bolt holding the strainer? Or can I just get the strainer and replace it after cleaning?
All advice welcome! I am in unknown territory
CJD
Nope! Very simple. When you remove the large plug it will expose the small bolt holding the screen. Unscrew the bolt and the screen falls out with it. You then also have to drain the tranny by it’s separate plug. There is no magnet on the OEM set-up.
Ps...check should reach you today or tomorrow...let me know if it doesn’t!!
TFB
My od unit was purchased rebuilt and does have the stacked magnets in the plug recess under the screen and small bolt and they do collect some gunk.
Tom
Dr_Mike
Thank you all ( especially John!) I am off this afternoon to undo that little bolt and see what follows it out. Will keep you informed.
Oh Joy
Dr_Mike
Surprise... not surprising really.
Oil was very clean: looked like PO had done it recently . Strainer was clean too.
Strainer had come out with the plug and is (was) not held in by a bolt. See photo that shows a protrusion on the plug..
I cannot see without a mirror but it seems that the bolt is held with a cotter pin or some such device and that the setup was original, but original to what? Moss catalogue and parts catalogue unhelpful.
Your going to need to find a bolt that will hold th strainer place, otherwise the strainer is not doing anything other than just sitting there. I think its a 1/4/20 bolt just a little longer than strainer.
Dr_Mike
thanx... I will also have to find or make the spacer to go inside the strainer. Ah , the joy of rebuilding, and the prayer that theDPO did not leave more faults for me to find.
CJD
The bolt is not a standard bolt, but rather has a long shank on it. The shank allows you to tighten the bolt without crushing the screen:
Also, the flat paper gasket around the big plug tends to leak. I went to Ace hardware and found an o-ring to go around the plug threads and used that. Not leaking at all now. If you do go the o-ring route, you do not need to over-tighten the plug. The rubber will seal and prevent the plug from backing off when just snug.
I'm still curious about the magents Geo and Tom are talking about. My early OD does not have them, but I would not mind adding them!?!
TFB
The magnets ,I think there are three,are stacked rings.They seem like magnetic screen embedded in a rubber like washer.Sorry no pics.The bottom of the screen sits on top and slightly inside in the hole of the rings,and the magnets od fits the plug recess.
When you remove magnets you can see the impression of the bowl screen in the rubber.
So they are held in place with no glue.I wipe them off to clean the gunk as the first time I shot them with some carb cleaner and it seemed like it was dissolving the rubber.
Tom
Dr_Mike
"Big Three" do not list bolt or spacer, so I am calling UK (Revington) to see if they can help. If not I shall have to find a way to make them (i.e. find someone who can do it for me). Do any of you have dimensions for those pieces?
Might as well add magnets while I am there!
Merlin63Tr4
I checked the S-T parts catalogs for the Tr6 (with A type OD), Tr250 and the Tr4A.
It looks like the OD filter attachment bolt/spacer/washer was deleted for those models.
The S-T parts catalog for the Tr4 does show those parts, but as it happens my '63Tr4 does not have the bolt, etc. But its OD does have the large drain plug with the spanner wrench slots.
It looks like the requirement for the filter attachment hardware went away with the change in the OD to the large drain plug with the spanner wrench slots.
These ODs do use a pump body plug (p/n 513902) that seals the hole used by the older versions of the OD units to attach the OD filter element.
This type of large drain plug has a recess to accommodate three large rubberized magnetic washers and a center protruding boss into which the center hole in the OD filter element fits, this boss centers and locates the filter element for installation in the OD.
Looks like OD units with this type of large drain plug depend on the presence of the magnetic washer stack to ensure that the filter element seals at the OD end.
I don’t have an OD drain plug like CJD has illustrated in his post for comparison to the latter version of the OD drain plug.
CJD, does your OD drain plug have an internal protruding boss?
M.
CJD
CJD, does your OD drain plug have an internal protruding boss?[/FONT]
M.
No it doesn’t.
One note...I ordered a new filter from Rimmers. It came as a beautiful stainless screen filter, but it did not fit my bolt. The filter was about 3/8” shorter. As a result I would recommend ordering the filter and bolt from the same vendor, if you can.
Dr_Mike
thank you all again for identifying the problem. I used all my ancient medical training and a gloved finger followed by a camera perched underneath the car to determine that there is indeed no hole for a bolt, and the OD must come from a later incarnation than shown in the catalogues or part lists. It does show up on TR250 an TR6 at Moss.
The magnets seem to be the same for them all so I shall order a set of three and be satisfied that I have done all I can
philstr6
Mike
the hole for the screen is in the bolt in the oil pump,in your picture there is no hole,the previous owner could have just changed the bolt and you still may have an early overdrive,whats the number on the overdrive
also overdrive spares has a great price on those magnets
Philstr6
CJD
Mike, i see a hex bolt in the center of the pump which is in the normal bolt hole for the screen bolt. So the bolt hole is still there, just plugged with a short bolt.
Dr_Mike
I looked through the TR250/6 parts list on Moss website and it shows a short "plug" ( a short hex head bolt ) in the base of the punp, which would correspond with what can be seem on my lousy photo I think it must be a vestigial remnant in the evolution of the unit, rather like my appendix.
Is there a number hidden on the unit that would give a clue to its origin? I will look. Without it we have a lot of guesswork.
At the moment, with the boss on the plug, I am inclined to think it is just a later version of the OD that may have more in common with the TR250 than the TR3/4.
I will check with Overdrive Spares.
D TR2/3/3A Overdrive question. Triumph 49
KVH General TR Overdrive Up-date and Clutch Question Triumph 2
K Overdrive Screen Replacement Order Question Austin Healey 4
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
D TR2/3/3A TR3A overdrive question Triumph 6
I Overdrive question..? Austin Healey 8
C BN1 Overdrive drain plug question Austin Healey 0
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
K Overdrive pressure question Austin Healey 4
S TR4/4A overdrive question Triumph 1
oxford overdrive question Austin Healey 5
B Overdrive Oil Pump Installation Question Austin Healey 10
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
stretchit2 Overdrive Question Austin Healey 5
A TR5/TR250 Overdrive question Triumph 12
M Exhaust fiasco & overdrive question Austin Healey 7
bighealeysource Overdrive question on BN2 Austin Healey 3
nevets Overdrive electrical diagnostics question Austin Healey 5
D A type overdrive question. Triumph 3
H overdrive solenoid question Austin Healey 4
J Overdrive Question Triumph 9
bighealeysource Overdrive fusing question on BN6 Austin Healey 10
J Overdrive transmission question Triumph 4
S Spitfire 76 spitfire overdrive test question Triumph 5
Coyote1 Overdrive wiring question Triumph 8
B Overdrive speedo cable question Triumph 6
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
G How sweet if was AND overdrive question Triumph 22
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
TR3TR6 J-type overdrive question Triumph 5
PAUL161 72 Overdrive rear oil seal question. MG 0
71tr J-type Overdrive Pressure Port Question Triumph 2
Monark192 MGB-GT 67 BGT - Overdrive Trouble Shooting Question MG 0
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
7 question after testing a J type overdrive Triumph 5
roofman Spitfire 1975 Spitfire overdrive question Triumph 6
T MGA MGA overdrive - that is the question MG 23
T Overdrive question - electrical Triumph 14
N And Another Overdrive Question MG 6
T TR2/3/3A TR3 overdrive question Triumph 5
6 Overdrive Escutcheon Question: Reversed? Austin Healey 1
curtis 100 overdrive question Austin Healey 5
Bob McElwee Overdrive Operating Valve Question Austin Healey 6
TR_Jim GT6 GT6 overdrive question Triumph 3
S Overdrive Question Austin Healey 2
