Results 1 to 4 of 4
Thread: Chasing Squeaks and Groans - Stabilizer Bar for starters
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Jun 2016
    Location
    Bay Area, CA
    Posts
    9
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I successfully installed a Speedwell stabilizer bar on my 60 Sprite. My Sprite has always made lots of creaking and groaning noises from the suspension. Today I decided to try to mitigate some of the noise. One place I noticed squeeking/groaning from is the stabilizer bar. Any suggestions on making it go away? Spray lube of some sort? It is installed correctly with the bushing in there and the stop nuts where they should be (I think).
    Also, suggestions for getting the rear end to quiet down a bit? Can I just spray lube into/onto the leaf springs?
  2. #2
    Senior Member 1974MGMidget's Avatar
    Join Date
    Dec 2009
    Location
    Grayson, GA
    Posts
    69
    Thanks Thanks Given
    Thanked in
    Re: Chasing Squeaks and Groans - Stabilizer Bar for starters
    If you have poly bushings in the swaybar and didn't grease them, they can squeak like crazy. There is a specific, very thick grease used for that. grease.jpg
  3. #3
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    615
    Thanks Thanks Given
    3
    Thanked in
    Just a touch of moly grease where bushings contact chassis and the bars.
    clean the bushing with alcohol to remove the mold release first.
    Door handles,Bootlid,Glovebox all fads
    59 sprite
  4. #4
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Apollo Beach, FL
    Posts
    5,518
    Blog Entries
    2
    Thanks Thanks Given
    6
    Thanked in
    When I rebuilt Springs on Bugsy IV I used a graphite paint from Tractor Supply on all sliding surfaces. But need to be apartvtobpaintbthem.
    Jim Gruber - Apollo Beach, FL
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new - 10/12 Painting done, reassembly, cutting, and buffing in progress.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
