Ring and Pinion
histerical
I pulled the drivetrain ( 1275 w/ Datsun) to paint the motor ( the one thing I skipped when I restored the BE 8 years ago), to replace the water pump, and rebuild the tranny. This is what I found. No wonder the starter would often not engage. I bought a new ring gear and starter pinion from Moss and noticed on the pinion box that it said " 10 teeth". I counted the ones on the old pinion and there were 9. The starter came from VB, I recall, and I don't understand why it was wrong. The teeth count on the new ring gear matched the old one ( also from VB I think). Replacing the pinion on the starter is a bit of a chore but doable.
zabond
I remember reading or being told that going to a 10t pinion was to increase the engine speed when starting [spins it faster]
Russ
histerical
histerical
I always thought that gears were indexed or pitch-matched and changing the tooth count on one required a corresponding change to the other and were used in sets. A 9-tooth gear could not have the same pitch or spacing as a 10-tooth one of the same diameter. Of course I could be wrong once again....
Rut
Since the ring gear and starter pinion are only engaged briefly during the starting process I don't think it matters as long as the teeth allow engagement. This is not like a matched gear set we commonly worry about shimming and measuring. Put that thing together and crank her up!
Rut
Joe Schlosser
Roll the pinion gear through the ring gear. It should move smoothly with the teeth engaging completely as it moves along. There should never be any misalignment of the teeth
histerical
histerical
I just think it is odd that Moss sells the ring gear for the 1275 and two pinions ( depends on the starter#) that both have 10 teeth and I had a starter with a 9-tooth pinion, which was quite chewed up along with the ring gear.
Joe Schlosser
just took a look at my collection of starters. 1 at 10 teeth, 4 at 9 teeth. I cannot tell which engine sizes they came from. a mix form all three sprite engines
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
T How do I clean sand out of a ring & pinion? Spridgets 2
JAV 3.5 ring and pinion Austin Healey 18
P Identifying a Ring and Pinion Austin Healey 8
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
K TR2/3/3A Ring and Pinion Wear? Triumph 11
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
B Ring and pinion question Austin Healey 29
aeronca65t Ring & Pinion Spridgets 8
R Installing pinion and ring gear Austin Healey 11
MikeAH100M Pinion/Ring Gear Lash Spridgets 2
A 3.54 Ring and Pinion Austin Healey 63
TulsaFred 3.90 ring/pinion Spridgets 24
I Correct ring and pinion gear ratio for Bugeye? Spridgets 5
Ed_K Used ring and pinion set for sale in classifieds Austin Healey 0
B spridget ring and pinion.. what type Racing 0
B Spridget ring & pinion What year? Spridgets 11
H 3.54 Ring and Pinion Austin Healey 16
Dave Richards 3.54 ring and pinion gear Austin Healey 13
Randy Forbes 3.54:1 Ring & Pinion... Austin Healey 5
C Ring and pinion question... Triumph 4
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
sail TR4/4A Piston Ring Question Triumph 6
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
DrEntropy MGB Ring Gear Roulette MG 12
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
sundown TR6 Proper ring gaps Triumph 6
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
I TR6 Aluminum trim ring band removal Triumph 5
T TR4/4A Attaching headlight trim ring Triumph 6
D BT-7 tri-carb ring gap Austin Healey 10
bfitz Zenith Stromberg O ring question Other British Cars 8
J TR6 Ring gear repair Triumph 13
KVH General Tech Hastings Oil Ring Triumph 13
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
JPSmit Question four - headlight trim ring Spridgets 9
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
