Results 1 to 9 of 9
Thread: Ring and Pinion
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Hopeful histerical's Avatar
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Ring and Pinion
    I pulled the drivetrain ( 1275 w/ Datsun) to paint the motor ( the one thing I skipped when I restored the BE 8 years ago), to replace the water pump, and rebuild the tranny. This is what I found. No wonder the starter would often not engage. I bought a new ring gear and starter pinion from Moss and noticed on the pinion box that it said " 10 teeth". I counted the ones on the old pinion and there were 9. The starter came from VB, I recall, and I don't understand why it was wrong. The teeth count on the new ring gear matched the old one ( also from VB I think). Replacing the pinion on the starter is a bit of a chore but doable.
  2. #2
    Join Date
    Oct 2016
    Location
    neerim east victoria australia
    Posts
    20
    Thanks Thanks Given
    Thanked in
    Re: Ring and Pinion
    I remember reading or being told that going to a 10t pinion was to increase the engine speed when starting [spins it faster]
    Russ
  3. #3
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanked in
    Re: Ring and Pinion
    I always thought that gears were indexed or pitch-matched and changing the tooth count on one required a corresponding change to the other and were used in sets. A 9-tooth gear could not have the same pitch or spacing as a 10-tooth one of the same diameter. Of course I could be wrong once again....
  4. #4
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanked in
    Re: Ring and Pinion
    How can both of these mate with the same ring teeth ?
  5. #5
    Darth Vader Rut's Avatar
    Join Date
    Jan 2008
    Location
    Tuscaloosa and Orange Beach, AL
    Posts
    2,881
    Thanks Thanks Given
    29
    7
    Thanked in
    Re: Ring and Pinion
    Since the ring gear and starter pinion are only engaged briefly during the starting process I don't think it matters as long as the teeth allow engagement. This is not like a matched gear set we commonly worry about shimming and measuring. Put that thing together and crank her up!
    Rut
    Rut, '60 Bugeye, '70 MGB, '62 TR4, '66 TR4a IRS, '67 TR4a IRS, '68 TR4a IRS, '72 TR6
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down 'happy'. They told me I didn't understand the assignment, and I told them they didn't understand life. John Lennon
  6. #6
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanked in
    Re: Ring and Pinion
    You betcha. Going back in tomorrow.
  7. #7
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    388
    Thanks Thanks Given
    10
    Thanked in
    Re: Ring and Pinion
    Roll the pinion gear through the ring gear. It should move smoothly with the teeth engaging completely as it moves along. There should never be any misalignment of the teeth
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  8. #8
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanked in
    Re: Ring and Pinion
    I just think it is odd that Moss sells the ring gear for the 1275 and two pinions ( depends on the starter#) that both have 10 teeth and I had a starter with a 9-tooth pinion, which was quite chewed up along with the ring gear.
  9. #9
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    388
    Thanks Thanks Given
    10
    Thanked in
    Re: Ring and Pinion
    just took a look at my collection of starters. 1 at 10 teeth, 4 at 9 teeth. I cannot tell which engine sizes they came from. a mix form all three sprite engines
    Joe Schlosser
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
