E-Type fuel tank mounting bolts [$&^##$%*!!]
Administrator
Boss
I don't swear often, but this job has caused me to slip a few times. I've got everything set to reinstall my fuel tank. I used a tap to clean out the threads on the mounting points, new rubber grommets installed on the tank - perfect!
But! Getting that bolt in the left rear mounting point started is going to drive me to drink! I just now came inside just to give it a rest for a few minutes. Obviously having the grommet holes lined up perfectly is critical to this task - but you can't see down the hole to tell how well it's lined up. You also can't get your fingers on the bolt very well to try staring the bolt by hand - and I have small hands!
Does anyone have any insight or neat little tricks to get this bolt started? Once it's started I can use a 9/16 open end wrench on it but dang - this is a bear!
Grantura_MKI
I did one a few months ago, as some jockey had used silicone to seal petrol!
if I remember, try using a few pointed bars to locate the holes you can see, and tape the fastener/washers to a long shallow socket on an extension. Best of luck with it!
65_BRG_Sprite
You had talked about getting into this project a couple weeks back- glad you pushed forward! Let us know how it goes after this little character-building niggle is squared away.
Administrator
Boss
So far I'm learning lots of new "words" that can't be repeated on the forum LOL! I've also lost about 5lbs from sweat! The problem is, these tank mounts, especially the left-rear, are very difficult to get to. The one in the left-rear especially I can barely get my fingers on the bolt to try and turn it to get the threads started! Spent a couple frustrating hours today with no luck! If I could just get the bolt started I could then get a 9/16 open end on it to get it the rest of the way. Not enough room to get a socket on it.
Did you chase the threads with tap before you installed tank? Starting threads may be rough enough it won't be an easy task. It might pay to remove tank and chase the threads good. Haven't done that job in a long time but I do remember it was pain to do. If its a new aftermarket tank, you might want to open up all the mounting holes just a bit to allow a little alignment wiggle.
Marv
Mickey Richaud
Also, are the bolts pointed? If not, get some; they make the job a LOT easier.
And if you need any more ~helpful~ words, I've made up my share! :tongue:
Administrator
Boss
Yep they are pointed. I bought them from XKS specific for this purpose. I may have to pull the tank out again and make sure the mounting bracket is completely straight else I'm trying to fit a straight bolt with fine threads into a mounting nut with the threads slightly askew. That's what I'm staring to think "may" be the issue. Because of shete this mount is locate, in the left-rear corner of the boot, I can't look down into the grommet.spacer tube, but I did manage to get my iPhone camera situated over the mount to take a picture. As you can see, the threads down their are signed up with the tube, but look like they "may" me slightly off alignment. Hard to tell for sure as it could just be how the cameras was situated.
Administrator
Boss
I've (reluctantly) decided to pull the tank back out and check the alignment of the mounting nut on the left-rear mount. I'm thinking it is slightly askew, thus preventing the fine thread of the bolt from starting.
Administrator
Boss
Hope you have the filler hose started on the tank?
Yes, I managed to get the Filler hose on. I used your trick (I think it was you) of cutting a notch so that I could push the hose up further on the neck earn installing the tank.
Grantura_MKI
Nope, not me. I use a lube that deasolves and leaves no trace. Be sure that there is no paint present on the connection.
the foam bit around the drain is a must have, as well.
good luck with it.
Administrator
Boss
Success!!! It is now 12:15 AM and I just came in the house after successfully getting the tank installed (well the hard stuff anyway). I'm now 5 lbs. lighter but it is done! Too tired to go into details right now, but I did a video of many of the steps I used in hopes that it will benefit the next poor sod who has to do this job! The tank is installed, the filler tube is installed, and the left-rear (as looking into the trunk) and left-front grommets/spacers and bolts are in! I still have to install the removable bracket at the rear right of the tank, but that now should be relatively easy (famous last words).
Also, I managed to get the left rear tail light wire harness routed correctly (I describe that in the video as well).
Good night!
Administrator
Boss
Not really.....they built the car around the prop shaft!!!!
Actually, if truth be told, they built the car around the heater pipes behind the bulkhead! I've replaced mine with Stainless and it was one heck of a hard job!
Grantura_MKI
That can be a fun job as well. Great looking motorcar, but there are a few jobs that are just not for the faint of heart!
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
NutmegCT Type L SU fuel pump Austin Healey 8
S banjo type fuel lines--vacuum advance Triumph 0
B E-Type fuel pump speks? Jaguar 2
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
B Series 1 E-Type fuel pump question Jaguar 2
nevets fuel filter type? Austin Healey 3
D location of fuel pump fuse on 1967 e-type Jaguar 3
nevets Fuel filter type? Austin Healey 3
K McLaren: Fiat/Mini Type Fuel Saver? Triumph 1
TRopic6 TR6 TR-6 Fuel Pump Diaphragm Failure [Red-type] Triumph 2
F S3 E-type Fuel Filter Jaguar 1
Gearhead what type of fuel? Spridgets 9
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
