Wanted TR3 Front Float Bowl Lid SU H6
frankfast
Looking for the front float bowl lid for an SU H6 carb. One of the brass fittings for the fuel line connection is cracked and bent. Moss doesn't sell the front lid.
TR3driver
Great Pumpkin - R.I.P
Are you talking about the early lid, or the later one? If it's the later one, those lines can be pulled out and replaced. I forget offhand what I used for replacement, might have been ordinary "refrigeration" soft copper tubing.
Or just buy a new one from TRF 506728
TR3driver
The Roadster Factory. 506728 is the factory part number for the later front float lid. (TRF uses the same numbers.)
F
frankfast
Just received a message from The Roadster Factory that the float lid is no longer available. So, does anyone have a spare?
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
K TR2/3/3A TR3 Front end..wishbone assembly end float??? Triumph 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
Kleykamp TR2/3/3A TR3 Front Emblem??? Triumph 7
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
O TR2/3/3A TR3 front End Alignment Triumph 8
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
S TR2/3/3A front bumper override tr3 Triumph 6
S TR2/3/3A tr3 front end alignment Triumph 9
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
B TR2/3/3A Tr3 removing front wings Triumph 8
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
