Results 1 to 5 of 5
Thread: Timing cover/crank hub oil seal Question
  1. #1
    Jedi Knight GTP1960's Avatar
    Join Date
    Oct 2014
    Location
    Chapin, SC
    Posts
    1,360
    Blog Entries
    65
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    The seal I got from Moss is different from the last one I installed.
    it has a metal band around the outside.
    wondering :
    A) is it as good as the old one?
    (no leak in two years)
    B) best install technique ?
    New one on the left side.
    Guy
    1960 TR3A TS63684L
  2. #2
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,460
    Thanks Thanks Given
    38
    Thanked in
    Re: Timing cover/crank hub oil seal Question
    What does your collar look like on the hub that is usually were the leak is caused? I am block of wood and hammer guy, but I am sure there is a proper tool. They make that go over seal sleeve also if your hub is grooved out too much, but I have never had any luck with that stuff; they make the hub to big. Clean up the hub with some fine paper and the seal will probably land in a different spot anyway and you will be fine or buy a new hub.
  3. #3
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    Yup, Block of wood or big socket. Just be careful to get it started evenly. The new seal is actually more like the original. Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  4. #4
    Join Date
    Oct 2014
    Location
    Chapin, SC
    Posts
    1,360
    Blog Entries
    65
    Thanks Thanks Given
    Thanked in
    Should I use halomar blue or an RTV in the base of the housing......don't recall using it last time, but it was a flexible seal ring.
    wish I had a socket that big.....might be time for a run to HFT.
    Guy
    1960 TR3A TS63684L
  5. #5
    Join Date
    May 2012
    Location
    Robbinsville, NC; Everglades City, Fl
    Posts
    654
    Thanks Thanks Given
    10
    Thanked in
    rubber mallet, hammer and wood. If the surface on which the seal lip rides is bad, you can take it to NAPA and get a SpeediSleeve to renew it. They can size them by mic-ing the thing.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
