TR2/3/3A Timing cover/crank hub oil seal Question
GTP1960
The seal I got from Moss is different from the last one I installed.
it has a metal band around the outside.
wondering :
A) is it as good as the old one?
(no leak in two years)
B) best install technique ?
New one on the left side.
sp53
What does your collar look like on the hub that is usually were the leak is caused? I am block of wood and hammer guy, but I am sure there is a proper tool. They make that go over seal sleeve also if your hub is grooved out too much, but I have never had any luck with that stuff; they make the hub to big. Clean up the hub with some fine paper and the seal will probably land in a different spot anyway and you will be fine or buy a new hub.
TomMull
Yup, Block of wood or big socket. Just be careful to get it started evenly. The new seal is actually more like the original. Tom
GTP1960
GTP1960
Should I use halomar blue or an RTV in the base of the housing......don't recall using it last time, but it was a flexible seal ring.
wish I had a socket that big.....might be time for a run to HFT.
bobhustead
rubber mallet, hammer and wood. If the surface on which the seal lip rides is bad, you can take it to NAPA and get a SpeediSleeve to renew it. They can size them by mic-ing the thing.
J Next project:: timing cover gasket and crank seal MG 2
M 1275 Timing Cover Vent Spridgets 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
A Timing cover access Spridgets 6
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
KVH General Tech Timing Cover Gasket Flub Up Triumph 4
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
C Wanted Timing gear cover 1275 Spridgets Classified 2
JFS General MG Timing Cover Oil Seal MG 7
B TR2/3/3A Timing chain cover goop location Triumph 4
KVH General Tech Timing Cover Seal Triumph 3
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
D timing cover Spridgets 11
vette Timing Cover crankshaft pulley seal Austin Healey 6
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
Dudly Sump and timing cover gaskets Triumph 1
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
TulsaFred Leaking timing cover Spridgets 15
J TR6 tr6 timing cover removal Triumph 3
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
L BN1 front timing cover seal Austin Healey 2
bugedd Tips on timing cover install Spridgets 4
bugedd Timing Cover Needed Spridgets 0
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
6 timing chain cover Triumph 4
R Timing cover oil seal MG 3
bugedd Timing Cover service Spridgets 1
bugedd Anyone have a timing chain cover? Spridgets 10
PatGalvin Timing Cover Seal Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
PeterK TR timing cover seal Triumph 3
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
Bruce_B Where does hose from timing cover go? Spridgets 6
KVH Timing Cover Gasket Replacement Triumph 4
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
KVH Timing Cover Seal Triumph 6
E TR6 TR6 Timing Cover Fasteners Triumph 7
ronzet Quick Query re: TIming Chain Cover MG 3
E TR6 TR6 Timing Cover Seal Triumph 7
E TR6 TR6 Timing cover removal Triumph 10
R interal thread stripped on timing chain cover Spridgets 2
TR4 Timing Chain Cover is stuck? Triumph 7
T Timing cover removal Triumph 15
S Stripped bolt on timing cover Spridgets 17
S Timing cover gasket sealer Spridgets 6
S Removing timing cover Spridgets 9
