TR4/4A Aluminum head water leak?
Have had a problem with some water up in the rocker area of the TR3(TR4A Motor) ever since I bought it last year. Just now getting to a point where I can pull the head and see if I can see what the issue is. Below are my observations:
1. Did not know it was an aluminum head until today, re-torqued it last year when I first saw this problem at 95lbs. Learned today it should be 70lbs.
2. Runs great, compression checks out good at 150-55 across all. But after getting up to highway speeds then coming back to town it quickly overheats and blows the water past the rad cap.
3. Cannot see any damage to the solid copper head gasket. Is this the right type gasket for an aluminum head?
4. Cannot see any damage to the head, how do you check an aluminum head? I would think that magnaflux would not work here.
5. Drained and checked the oil last fall, no water present in the case.
Any suggestions from the collective wisdom would be greatly appreciated, seems this motor was intended for some level of performance as it also has Moss’s roller rockers.
sp53
Sometimes on the tr3 and 4 motor the block cracks where thehead stud go into the block. The reason is people sometimes tighten the studsdown then apply the head and torque the head down compounding the torque on thestuds, cracking the block at the stud. This gives the same symptoms youmentioned.
Steve
charleyf
A novice answer is that you appear to have a water to compression leak. When this happens you get what you describe as the excess pressure in the radiator and overheating. Did you see any signs of water getting into any cylinders? This would happen after the car shuts down especially. Could be the gasket did not seal off the cylinders and allows the compression to leak over to the water passage. There is a chemical that you can use to put in the radiator water to test if combustion gases are entering the water.
Easiest thing is to pull the head off and look at the gasket for signs of water leaking into the cylinders. Much running of the car with water in the oil can damage the bearings. At the early stages you are still good.
Charley
M_Pied_Lourd
Is your head actually aluminum or are you talking about the aluminum plug in the head?
Cheers
Tush
PatGalvin
If you hot tanked your cast iron head, the aluminum plug can come loose or be porous and leak coolant into the oil. Ask me how I know!!
I had the head threaded and fit a black iron pipe plug in that hole.
Pat
CJD
I'm with Steve and Pat. Either a cracked head, loose plug, or a crack in the block at the front or rear studs. Those are the only items that give you water in the rocker area.
charleyf
But what about the overheating and excess pressure in the coolant system? You need compression for that to occur.
Charley
sim 948 aluminum head gasket Spridgets 2
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
johntennyson Aluminum Head? Again? Spridgets 4
rjc157 Aluminum Head Austin Healey 1
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
rjc157 aluminum head Austin Healey 4
Go_Dogs_Go Aluminum Head? or Original? Spridgets 27
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
H Healey 100 Aluminum Head Austin Healey 1
kyreb1862 Aluminum Cylinder Head MG 6
Trevor Jessie Aluminum Head ..stud question Spridgets 4
T TR6 Aluminum TR6 head..... Triumph 7
A Denis Welch Aluminum Head on a 100M Austin Healey 9
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
Louie Aluminum 4 cyl head Austin Healey 9
kodanja TR6 TR6 Aluminum head? Triumph 3
kodanja Aluminum Head...? Triumph 3
M Aluminum Head Austin Healey 59
V8Blazer thoughts on aluminum head MG 15
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
