Spin-on oil filter for BJ8
SteveT3000
I did the same on my BJ8. Looked around and there seemed a few versions, some with quite small filters. In the end I went for Denis Welch's one that came with a good size Wix filter. Easy to do and although I read about people struggling to get oil pressure after on start up, I had no issues. I did fill the filter as much as I could before I fitted it though.
Now the oil pressure is up immediately on starting as it doesn't drain down like the old one did. Worth doing and less messy on changes. Hope it helps.
Steve.
I have the Moss one. Has worked just fine since 2000.
Same here, for 20 years at least. I just put the same one on the BN2, but there's a 'quirk' with the 100 adapters: BN1s use a BSF thread in the block and, supposedly, BN2s use UNF (or whatever the later, standardized thread is). HOWEVER, some BN2s had the BSF threaded block--guess which one yours truly has (required a special order to Moss for the cap screws). My BN2 is a 100M that also used one of the 'oddball' distributors, but it's all original. Now I buy filters in 'bulk' for both cars (and use the same oil, too).
Just keep the canister in case you ever want/need to sell the car (or you decide you just don't have enough Healey work to do). And, though the filters look kinda small they appear to hold nearly the same volume as the filters on my 4.6L Mustang.
bdcvg
I stayed stock using Wix canisters. I remove the whole assembly from the side of the block which makes mess control easy. I do have a lift which helps and I keep a few of the block gaskets around. I only change the oil 2x a year so It's not really a hassle.
CraigC
I had the same problem with my very late production BN2, which is also an "M".
The filter used fits a very large number of Ford products which makes it easy to find and cross reference to one's favorite brand.
Keoke
I stayed stock using Wix canisters. I remove the whole assembly from the side of the block which makes mess control easy. .
ME TOO!
Cept i have a complete buit up spare canister assembly.
While the shop peole are draining the oil, I remove the dirty assembly from the block hand it to a tech to dispose of the filter and clesn it up.While he is doing this I install the clean spare painted assembly.
Back home I clean the assembly removed from the engine , Install new filter paint and when dry place in a plastic bag to keep it clean until next oil change.
Fortunately I also bought two cases of WIX felt filters so i am good to go
... The filter used fits a very large number of Ford products which makes it easy to find and cross reference to one's favorite brand.
Yeah. The filter Moss sent with my adapter--it was extra, of course--was a Fram PH3600. Fram doesn't have a great reputation--but I've never known one that failed, and the quality has supposedly improved--so I switched to Wix years ago. The x-ref for Wix is #51516, a case (12) of which can be bought on eBay for about $50.
One filter used on a lot of Fords, including my dad's '55 T-Bird and '65 Mustang is Fram PH8. It's a big sucker.
If I'm not mistaken, that crosses over to their HP-1 (high performance) filter, as well as other manufacturers. The HP-1 uses an anti-drainback (if the PH-8 doesn't) and may offer higher filtration and/or flow rates.
The remote filter mount on BN6L/942 uses the PH-8/HP-1 size filter, hanging straight down, so it can't drain the oil out if it wanted too. This also allows me to completely saturate and fill the filter before installation. But for the life of me, I couldn't tell you what brand of filter is currently on the car; I know it's black, and my date/mileage lettering shows up nicely... :eek:
My ex-brother-in-law used to give me Baldwin industrial filters, which had a solid reputation, but I've gone and blown that connection (for a while, I had all the Healey & MGB oil filters I could use).
John Turney
I use the Fram XG3600, which is better built than the PH3600, to get around the poor reputation. I get them from Amazon. They aren't carried by our local generic APS.
bdcvg
I have found or ordered Baldwin filters at heavy equipment\ truck parts stores. They have a great rep for anti-drain back which was a big issue on the Ferrari 328 I had for awhile. 13$ compared to 50 for ones from the Ferrari dealer.
One thing I've wondered about 'anti-drainback' valves in oil filters is, although the anti-drainback valves block oil from flowing from the inlet holes, what keeps oil from flowing out through the output hole (the big one in the center)? Oil is forced through the filter material under pressure through the inlet holes through the outlet hole, but even without pressure oil can bleed through the filter material. I think the only thing that can truly prevent this is to mount the filters vertically with the holes on top.
John Turney
When the oil level in the filter gets below the outlet, it stops seeping out.
RAC68
Hi All,
I hate to go against the tide but I still use the original filter system and find it not that difficult. I loosen the 2 long bolts with the canister in place and remove right bolt and tilt the canister/unit down before totally removing the remaining bolt. This allows me to lift the total filter and mounting out of the engine compartment with little or no mess and drop it into an empty oil pan for cleaning and refitting.
I don't think it is cleaner then a spin-on arrangement but then I only change it one a year and sometimes twice, depending on distance driven. Given that infrequency and my use of Mobile 1 15W50 synthetic, the amount of mess saved is quite low and does not justify replacing the original...to me. Although I like Keoke's idea of having a second original filter setup ready to go to save time, at my frequency of my replacements, I would probably have forgotten where I put it when ready to use .
Ray(64BJ8P1)
Michael Oritt
Try to find an adapter that has the filter hanging vertically as Randy described--it will allow you to fill the canister before mounting it to the engine and so avoid the possibility of a big slug of air going to the oil pump.
crya
Member
Getting ready to tackle this year's first oil change myself. Anyone point me to this vertical adapter that works with the Moss spin-on adapter? I can't seem to get a search to turn up what I think you're discussing, basically an elbow?
Healey Nut
Whats the part # on the Wix felt filter inserts ?
Csarneson
I'm still assembling my engine (delayed by a broken ring) so I haven't tried it, but is there a reason a person couldn't just use the elbow from the canister assembly with the spin on adapter to make it vertical? Everything appears to line up. I can't tell yet if some of the engine bolt-on extras (starter, generator, ...) might be the reason this isn't done. It seems like such a no-brainer...
Chris
bob hughes
I changed to spin on after a disastrous change over with the original system, something was wrong with the oil seal, I could not get it to sit properly for some reason and nearly lost all my oil on a test drive. Had to get a tow back from the catering management - most embarrassing.
:cheers:
Bob
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
