TR2/3/3A Coolant System Hoses Slipping
PatGalvin
I stole this photo from John's TR2 rebuild thread (which is amazing, by the way).
Have any of you had problems with the hoses slipping off the thermostat housing or the water pump. I have problems with both of these locations, given there is little or no lip on the cast hardware so the hoses are held in place solely by the clamping force. I tighten the hose clamps with a lot of force but to no avail. After a few hundred miles, they are leaking or starting to slip off. I just bought some super duper clamps on Amazon and hope to install this weekend. Maybe that will do the trick. I was even thinking of adding some JBWeld on the end of the hardware to create a bit of a lip to hold the hose and clamp on.
Thoughts?
charleyf
Pat,
I have never had any problems with hoses slipping off even using the traditional wire clamps.
Are your hoses long enough?
Charley
TR3driver
Great Pumpkin - R.I.P
I've had trouble with the bypass hose at the thermostat housing. I eventually used a file to remove some of the taper; and cut a groove near the end, to give the hose something to grab. The water pump side is pretty rough (from rust), don't recall having a problem there.
But I also use worm-drive hose clamps, which can exert a lot more force than the original style clamps. I get the all-stainless ones from MMC.
TomMull
I agree with Pat, mine didn't slip. Perhaps aftermarket hose is a bit loose? Randall's solution seems good though. I've uses 3M 5200 (because I had it) on hose connections with success too.
Tom
CJD
The only car I've had trouble with hoses slipping off was my XJS with the V12. Those Jags have at least a dozen little hoses, many with no locating lip. The way I finally solved the slipping is to smear a bit of RTV silicone sealant inside the hose...enough to cover but not enough to squeeze out into the coolant system. I then clamped as normal, but allowed the silicone to set overnight before I added coolant and started the car. That solved all but one hose. That one I had to file some rough grooves to get it to stick.
In your (my) pic, I had to pop off the hose to reroute the vacuum line. The hose was actually stuck on tightly, even after the clamp was off. I had to pry it apart. That points out that rubber tends to stick to metal when clamped to it. It may work to make sure the hose and pipe are very dry and clean, so the rubber doesn't have any lubrication and has some time to "bond" to the metal.
PatGalvin
PatGalvin
I pulled the offending hose and cleaned well. Then scuffed up the surface of the water pump where discharge end is slightly tapered. I used a die grinder with a tip that would be used for porting a cylinder head. Finished with some 180 grit sandpaper. Was a little messy but it seems to have done the trick. I don't think the hose will slip off now. Thanks for the feedback.
Pat
I TR6 TR6 Coolant System Problem Triumph 5
philman Wedge tr7 coolant system differences Triumph 1
Lin coolant recovery system Spridgets 2
C Coolant Recovery System Austin Healey 41
J Coolant System Flush Austin Healey 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
