Pinto Engine In Bugeye
P
Paul McGuffin
This is on eBay now....Pinto Engine
Boink
Bronze
Rather tidy.
P
Paul McGuffin
It’s hard to believe that stock radiator is big enough for a Pinto engine, even with the cooling fan added. I have yet to see an engine swap, where they retained a heater.
PM
Boink
Bronze
PM
It looks like they took out the entire battery-tray/heater shelf (and the interior photo suggests a modified tunnel).
And, of course, the wipers are gone.
Deleted member 8987
Pinto fours had fairly small radiators. I had one...a 72 wagon, 2.0L auto for the wife. Nice little car. Got a free Fairmont Squire with 302 and air from the in-laws, so sold off the little Pinto.
Used to work on Pintos, never could remember an overheating problem unless the 2.0L head cracked (more common than you would imagine....I kept a couple of spare heads around until Pintos dropped off the charts).
SD Bugeye
Rather odd choice for a swap
i think I could come up with a more reasonable swap.
seems odd why pick a that?
maybe a cosworth from a vega but a pinto
i know it shares a lot with the cortina still...
Deleted member 8987
I would imagine availability of parts and cost.
You can still pick up about anything you need for a 2.3L Ford engine (as used non-exclusively in Pintos).
Just how much would a Vegamatic Cosworth set you back, and would parts be readily available in East Nowhere, North Dakota?
I think it's a neat install, with the sidedraughts and headers, on a light body, I would think it would scream.
nomad
PM
My Datsun swap retains the heater and if it wouldn't I wouldn't have done it. Even in warm climates you need to occasionally defog the windshield.
Kurt.
P
Paul McGuffin
I don’t understand why he didn’t move things around and keep the windshield wipers.
PM
nomad
I'd be more impressed with the early pinto Kent engine. The engine that powered Formula Ford and an engine that's been tweaked into the 200HP range.
Kurt
P
Paul McGuffin
Here’s a BMW Bugeye! Very clean job, but again, now windshield wipers
P
Paul McGuffin
The one thing I’ve noticed about all these Sprites, with engine swaps is....they all lose their heater. I need a heater..period.
nomad
TC, saw your post on another forum, This one hasn't modified the bonnet apparently because the engine has been moved so far back. Don't remember if yours retains the heater.
Kurt
Pat MM
Does anyone have pictures of a Kent 1600 (early Pinto) in a Bugeye, or Spridget?
(Or a Morris Minor for that matter! They have clearance problems with the steering rack at the back of the engine bay so folks notch the manual transmissions to clear, or set the engine too low, like mine that has a Datsun A14 engine with an old 3 speed automatic, yuck!)
That may be my next project if I can figure out a tranny / bell housing combo without breaking the bank! I've got the engine already.
nomad
The early Pinto [Kent] engine is worth good money. I'd advertise it and keep the Datsun engine but with a standard trans.
The pinto engine was the base for Formula Ford and many other competitive cars.
AngliaGT Pinto Wagon Spotted 13
D Pinto is GONE!!! Racing 17
aeronca65t 907-powered Pinto Other British Cars 6
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
