TR2/3/3A Hardtop bracket
tomnanney
Has anyone made any of the hardtop mounting brackets? There are five on the bottom of the top and I am missing the middle one. I have posted in the classifieds for one, but I may be able to make one. Any suggestions?
thanks
adcronin
I had to make mine. Used 1/8" thick x 1" steel stock and cut out, bent and drilled. Then had them chromed. I may be able to locate the patterns I used if it helps you. May take a little time to go thru "stuff" to find however. I can also take some photos of the brackets if that helps with a tape measure for scale.
thanks
mrv8q
I'm missing one as well. If there is any part of the TR3 I could make, it would be the hardtop mounting bracket.
M_Pied_Lourd
adcronin
Folks: I have been trying to attach photos and a drawing to this post several times with out any success....so if you would like a 1/4" scale drawing of the hardtop brackets and 8 photos, send me a PM email and I will send all to you by return email.
Dan
M_Pied_Lourd
Posting for Dan,
Thanks Dan! We appreciate it
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
Thanks to both Dan and Tush!
Just for clarity, I'd like to point out that the original angle brackets on the hardtop were not chromed, just painted. I'm not sure if the color always matched the hard top, but mine are an off-black (or dark gray) for a black hard top and the ones on a light blue HT that I recently sold were more of a light gray color.
mallard
The brackets on my car were painted body color.
T
tomnanney
I am having a hard time fitting the hardtop on the car. Maybe it is because it hasn't been on in 25 years!? Or maybe it's just me, but it doesn't seem to want to fit very well. Do the peg"fit the dot" pieces on the back have to be removed? I thought they would fit in the opening on the bottom of the top, but I am having some difficulty with it. I don't mind removing them, but just wanted to know if they are suppose to be removed?
Any help is appreciated.
tom
TR3driver
Mine fit over the pegs; but the original pegs were shorter than the replacements available today. I've never figured out if they were special pegs to fit under the hardtop, or if the pattern just changed over the years.
doc50
I'm starting to fit the hard top I got from Randall.
Re: side / rear attachments, does anybody know if the (2) U shaped side support brackets are the same dimensions as the (3) brackets at the rear? I know the cosmetic aluminum covers are different side vs back, but I don't know about the hidden support brackets. I see the holes are there from the factory which makes it easier.
I'm making all except the (3) windshield brackets, which were already there.
Thanks,
Thom
1959 TR3
#TS34909L(O)
M_Pied_Lourd
Thom,
If you look up a little bit in the thread, I posted a pic that I think are the brackets you are asking about. There are two different sizes.
Cheers
Tush
doc50
Thanks, Tush, I've looked at the pix and I still don't see the different sizes. Your pix of the brackets appear to be the same size. I used your drawings with the dimensions for the three rear brackets but I just don't see the side bracket dimensions.
Thinking as I type here, I guess I could dry fit the top and use that to get the measurements.
Tush, a question: How did you bend your brackets? They look very nice. I'm trying to use a vice and torch but mine are not nearly as clean and neat as yours.
Thom
1959 TR3A
#TS 34909L(O)
M_Pied_Lourd
Hi Thom,
Sorry but not my pics or drawings...some are from Dan. The others are off another forum.
Cheers
Tush
doc50
I'll just dry fit the top to get measurements. That will clear up my confusion....I hope!
I'll just need the dear wife to feel particularly benevolent and helpful that day....pray for me....
Thom
1959 TR3
#TS34909L(O)
doc50
Here are my rear hard top brackets. I got tired of seeing big bucks for brackets.....so I made the support brackets based on M_Pied_Lourde's specs (thank you) from bits I had, and found a section of 1" aluminum pipe for a little south of $10.00.
Took under an hour and they look fine (for my purposes).
Thom
1959 TR3
#TS34909L(O)
M_Pied_Lourd
They look great Thom.
Cheers
Tush
Jim_Stevens TR2/3/3A Hardtop bracket Triumph 4
T Wanted Bracket for TR3 hardtop Triumph Classifieds 1
M TR2/3/3A TR3 hardtop bracket question??? Triumph 2
dougie Healey Hardtop on BAT Austin Healey 8
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
Celtic 77 For Sale MG B hardtop for sale MG Classifieds 15
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
R TR2/3/3A Hardtop hardware- Triumph 4
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
T Wanted TR4A hardtop Triumph Classifieds 2
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
P For Sale 1958 sunbeam rapier convertible and hardtop (coastside/pescadero) Other British Classifieds 0
Patrick67BJ8 Hardtop Vents Austin Healey 10
P For Sale MGA factory hardtop for sale. MG Classifieds 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
Celtic 77 MGB factory hardtop question... MG 10
prb51 Hardtop Indentification Austin Healey 13
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
D Wanted TR6 hardtop fraud/scam ALERT Triumph Classifieds 5
B Wood Braces, Hardtop Austin Healey 3
apbos BT7 Hardtop For Sale Austin Healey 0
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
R TR2/3/3A TR-2 Hardtop Hardware Triumph 9
AUSMHLY BJ8 Factory Hardtop Headliner Austin Healey 2
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
tr6nitjulius General TR TR6 Hardtop Time! Triumph 0
Healey Nut Hardtop-to-Shroud Seal Austin Healey 12
maxwedge5281 Hardtop Security Austin Healey 10
B Roof vent position on BN7 hardtop. Austin Healey 15
C Also hardtop troubles. Austin Healey 5
J TR6 Hardtop/Soft Top Installation Triumph 2
J For Sale TR6 hardtop glass Other British Classifieds 0
Lin Hardtop Wall Storage Rack Austin Healey 11
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
M TR4/4A Honeybourne "Racing" Hardtop. Triumph 3
J TR6 TR6 Hardtop Hoist Triumph 2
J Wanted TR6 Hardtop Hoist Triumph Classifieds 1
JPSmit Interesting project - and a twist on the hardtop. Restoration & Tools 12
T BT7 Hardtop Restoration Austin Healey 6
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
Rob Glasgow Hardtop Stand Austin Healey 9
B Wanted MG TD hardtop MG Classifieds 1
H 4 seater hardtop on BAT Austin Healey 0
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
tr6nitjulius General TR You May Not Know? Hardtop Installation Triumph 4
GeorgeC Hardtop glass removal Austin Healey 2
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
