Hi guys, happy new year.
I don't visit here as often as I used to. Just so happens today I did and I'll chim in on what I did years ago. Here's the link, spoiler alert, lots of reading.
https://www.britishcarforum.com/bcf...e-with-LED%92s&highlight=brighten+dash+lights
Here's the need to know about led as gauge bulbs.
Stock bulbs are incandescent 2.2 watt E10, screw type.
If you replace with an led, make sure your car is negative ground. If you're staying positive ground, isolate the housing or buy led's that will work with positive ground. Moss now sells both, neg/pos led gauge bulbs.
As mentioned, most led's are forward beam focused. There are many that have a chip on the top that spread the light out more like an incandescent. My write up addresses that.
Pros/cons.
Led's are brighter but color is usually blue/white.
Once you find the right E10 led that disperses the light like the incandescent, it still will not light up the gauge fully. It will still be brighter where the bulb is and the other side will still be a little dark.
Here's a link to the ones I used E10 Superstar Led Bulbs
https://www.autolumination.com/otherleds.htm
How to illuminate the full face of the gauge? Drill a hole in the back of the gauge accross from the factory one and add another bulb holder.
Now I had 2 E10 led 1watt full dispersing bulbs. Just too blue/white for me. Looked too modern.
What I ended up with was, two 2.2 watt incandescent bulbs in the large gauges. Filled them in nicely and has the correct shade of light.
For the two smaller gauges I replaced the 2.2 watt bulb with an incandescent 4 watt oblong bulb. (no room to ad another bulb in the small gauges)
Eventhough Moss recommends not using an LED bulb...
"LEDs should not be used for turn signal indicators, or for the red generator/alternator light on the dash"... I did.
I can now see the signal indicator during daylight. Could not before. I've had no problems replacing those. I'm negative ground.
