Running out of gas
Daniel Kaminsky
Gentlemen:
I have been running out of gas in my BJ8 when the gauge reads 1/4. Can it be that my sending unit is installed backwards? Does the wire normally face towards the front of the car, or towards the back(mine faces forward)? So maybe the float is not going into the sump. Can't think what else it could be.
Thanks,
Dan Kaminsky
My BN2's gauge used to read low; e.g. a full tank registered as 3/4. I bent the heavy wire that suspends the float down a bit and problem solved. Your problem is, of course, the opposite, but bending the float/wire up a little might do the trick.
Duane_Rhynard
Gentlemen:
Thanks,
Dan Kaminsky
Dan,
Most of the info you need I think is at the link below!
Duane
https://www.britishcarforum.com/bcf/showthread.php?89931-BJ8-Fuel-Gauge-Shows-1-4-tank-when-empty
BJ8Healeys
Gentlemen:
Thanks,
Dan Kaminsky
The terminal for the wire on the sending unit goes toward the front. Is the problem with the gauge something new?
Michael Oritt
I get a consistent 22-23 mpg "around town" and 24-25 on the highway. I gauge (no play on words intended) my need to refuel by what the accurate, resettable tripometer tells me--at 200 miles I am looking for a gas station.
Daniel Kaminsky
Forgot to mention that the fuel gauge is stuck on full, and it does seem to be a new problem. There seems to be some contradictions on which way the sending unit wire terminal faces? Should I just take it out for a look, although I hate to do this if unnecessary.
BJ8Healeys
On a BJ8, at least, the wire terminal goes toward the front. That puts the float arm forward so that it can go down into the well in the bottom of the tank (that sits in the rectangular hole in the boot floor, on the forward side of the tank. That allows it to register those last few precious drops of fuel.
All that said, the last time I replaced my sending unit, I discovered that the float arm apparently was hitting the forward wall of the tank. I turned it one fastener hole counterclockwise and the fuel gauge doesn't stick anymore, but also doesn't register completely full.
The photo shows a replacement sending unit from Moss Motors that originally had that crappy plastic float that always arrived pre-cracked. I replaced the float with a Ford brass float, but the unit was still too erratic to use.
steveg
I believe stuck-on-full is a symptom of wiring or ground issues. Before you remove the sender, suggest running a separate ground wire from top of sender to a chassis ground in the trunk. It may also be the result of a broken tiny wire inside the sender.
MGA Guru site has tons of information:
https://mgaguru.com/mgtech/electric/fg110.htm
BJ8Healeys
The mgaguru site is good, but be advised that the 68 ohms quoted for the MGA calibration procedure should be 90 - 100 ohms for the Healey fuel gauge. Building a calibration test set according to the mgaguru information is fairly simple, but there are some cautions to be observed when actually calibrating a gauge. It's easy to break a coil wire if you allow the guide foot of the terminal post (inside the gauge, so you can't see it) to come out of its track. If that happens, you can spin the post while tightening the nut and that breaks the wire. The next step is to send it to a professional gauge rebuilding service.
BJ8Healeys
Do the 4 cylinder Healeys get better fuel economy than the 6's? Seems logical.
Apparently so, if Michael Oritt's 100 gets 22-23 mpg around town and 24-25 on the road. My BJ8 gets consistently 22-23 mpg on the road. I've never bothered to check it around town, since most of my mileage with the Healey is on the road, usually on long trips.
Like Michael, I don't rely on the fuel gauge to determine when to refuel. When I reach 200 miles on the trip odometer, I begin looking for a place to tank up.
Maybe I'm too picky, but I want all my gauges to be at least nominally functioning (I spent years and dollars getting a reasonably good speedometer indication). Yeah, the fuel gauge bounces around like crazy, but on smooth, flat roads at constant speeds should give a reasonable readout. I too get 23-24 on my BJ8 up to about 65MPH but, on freeways when I need to go faster than that to not be run over by a housewife in an Excursion the mileage drops off considerably, to about 18MPG. That's 216 miles on a nominal 12 gallon tank, and that's cutting it pretty close. My aftermarket tank actually holds a little over 13 gallons, but I try to 'forget' about that unless it's absolutely needed.
Mert
https://www.ebay.com/itm/Austin-Hea...m2eb5c1b938:m:meuJPea5AUMjJa295HTIcog&vxp=mtr Click on this link. A BJ8 buddy of mine had issues with his fuel gauge not reading accurate. The needle was bouncing all over the dial. He had run out of fuel too many times. I ordered the fuel sensor listed in the link. I installed it in his BJ8. Then I took the old sensor apart. The spring coil was worn in 2 places. the tightness of the coil was gone, leaving gaps for the needle to get stuck. The one installed has 2 brushes and is more intact. Now every time I see my old pal, I always get a slap on the back and a big thank you. He paid me for the work, but I am satisfied that he doesn't have to worry about running out of fuel. At the time I did this, I owned a 60 BN7. It's been sold and is back in England.
Hmmmmmm ... The ad says '[FONT=arial, helvetica, verdana, sans-serif]3000 models except BJ8.' (emphasis theirs). Are you saying you put one in a BJ8 anyway? What's the difference for a BJ8 (never heard there was a difference in senders for the 6-cyl cars).[/FONT]
Mert
Just ignore the ad. It works in a BJ8. I put the new sensor in his Healey over 3 years ago. He has had no problems since the upgrade.
OK, but now I'm curious. Moss shows a different part# for earlier 6-cyls and BJ8, anyone know what the difference is?
steveg
I seem to recall it's the resistance which is different for the different gauges between the BJ8 and previous cars.
IIRC - with the float pointed forward, the wire connector on the BJ8 is to the front; others to the rear.
Keoke
I only rely on three states of my fuel gauge.
1] it does not move at all after fillup== Tank FULL
2] it starts bouncing around== I got GAS
3] it ain't bouncing no mo!==Need Petro
Rut MGB Running out of gas symptoms MG 21
T Gas running from carburator tube?? MG 1
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
M TR5/TR250 problem getting engine running Triumph 15
D Nice to hear the old girl running again. Austin Healey 2
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
