steve burton
Hi Guy
Can you help
i am restoring a bj7 Healey and i need a bit of tech help
i have 2 tech question
first is there a measurement for the front main floor which sit in the out riggers? the front edge is not straight and tappers away towards the gear box
the heel floor is straight
so is they a gap dose it touch at the sill edge and then gap opens out toward the gear box
i cant check the other side as the floor are rusted away
tech question 2
i am replacing the front heel section and the inner and outer side panels
with the inner panel (gearbox tunnel) side in place it seams to lift the front body tub away from the chassis
it seams the panel it 13mm to tall is it comman that these panels need a bit of fetling
ps the front tube is sitting on a new chassis
all parts purchase fro head 4 healey
i hope i have explained it well
Can you help
tech question 2
