MGB Windshield Frame removal questions.
How the h#$* do you get to the top bolt? I've been trying for an hour. I can't even get a socket on it. And there is a screw between the two bolts, does it have to come out too?
Mickey Richaud
Ah, yes - what fun! Unless you remove the dash, it's a real bear. Even then, it's no picnic. Been a while, but if memory serves...
On the passenger side, if you remove the glove box, you may have a better shot at it. And on the driver's side, try pulling the brake warning light thing (if so equipped). You may have to loosen the outboard dash mounting bolts so you (someone else, really) can pull it out a bit, as well.
Maybe someone who's had a bit more fun with them will chime in with more help.
Good luck!
Mickey
kennypinkerton
Thanks. I think I'll just go ahead and pull the dash first. It's all gotta come out anyway.
kennypinkerton
I was hoping to get it so I could remove the fenders first thing tomorrow.
bob67bgt
The screw should not be removed. It holds the spacer in place. If I recall correct 77 and newer is easier than the earlier padded dash cars. Still a bear of a job. I have a snap on 9/16-1/4" flex socket that helps a lot for this job. Getting it out is the easy part!
MustangSix
A 9/16" ratcheting wrench usually does it for me. I can usually slide it in between the dash and the pillar to get it on the bolt head.
Platinum
The ratcheting wrench is about the best solution, and as Bob said, getting it OUT is the easy part.
I'm on record here someplace as stating I'd rather do three MGB clutch replacements than one windshield R&R. :smirk:
PAUL161
If you use the attached bottom rubber, considering it's in good shape, then putting the frame back is not much of a problem, but if your installing a new bottom rubber, then that's a different story. Compressing a new rubber to get the bolts in takes a little doing. More than one windshield glass has been cracked while doing this. PJ
bob67bgt
I have a 72 in the garage waiting for me to put a new windshield in. I am not pushing V.B. on the back order since the job sucks . I would also do 3 clutch jobs to one windshield if given the option.
PAUL161
They are not a problem. Have done some odd 25+ over the years, whilst converting pad facia cars to steel.
Well, their not a problem for me either, but for someone who hasn't done it before, it can be a problem not knowing the proper procedure. PJ
Mickey Richaud
MustangSix
One thing that helps me on reinstall is to use a 3/8" x 16 pilot tip bolt such as the GM or Ford body bolt. The OEM bolts are flat faced and difficult to get aligned and started. The GM/Ford bolts align themselves if you just get them in the hole. Also, the washer is captive so it won't fall out as you're trying to insert it.
If you really want to use the original bolts you can use these to install the screen and then swap them out one at a time for the OEM bolts and washers.
Grantura_MKI
The original bolts were tapered for this. You can load a spare nut in the socket to help. I have many short sockets, but probably don't?
JPSmit
great idea - do Domestic car bolts come in fine thread?
kennypinkerton
Well, I finally got that bolt off today after loosening the dash a bit. And I used a ratchet wrench while prying up on the corner of the dash. The windshield is off... do I need to remove the spacer screws to remove the front fenders?
kennypinkerton
And after I got the dash off and looked closely at it, the answer is no. The spacer screws don't need to come out to remove the fenders. I may remove them after I take the fenders off anyway though. There is a lot of dirt in there.
MustangSix
JP, those windshield bolts are 3/8 course thread.
Here's a pic of one of them I just took out last week. Flat nose, no taper, 3/8 coarse thread.
Windscreen bolt.jpg.
JPSmit
View attachment 46724.
thanks! It has been a while since I did mine (Midget) but I hadn't realized it was Course thread - good to know! and still a great idea the bolts.
mrv8q TR2/3/3A Windshield frame/doglegs removal Triumph 10
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
G TR6 TR6 dash and windshield frame removal Triumph 13
D TR2/3/3A Windshield frame fitting. Triumph 2
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
P Rivets on windshield and vent window frame. Austin Healey 1
P TR2/3/3A TR3A Windshield Frame Curved or Flat? Triumph 7
K TR2/3/3A Windshield frame Tenax fastners with small nylon spacers? Triumph 10
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
M Helicoil in windshield frame Spridgets 13
M Side Curtain Windshield Frame ? Spridgets 0
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
S MGB Tonneau cover - snaps on cover, twist locks on windshield frame MG 7
J TR2/3/3A 1960 TR 3A windshield frame. Triumph 10
Marvin Gruber A/H 100/4 windshield frame Austin Healey 9
S TR6 TR-6 windshield frame Triumph 9
A TR2/3/3A TR-3A windshield frame disassembly Triumph 4
L Stripped windshield frame screw hole Spridgets 6
J Windshield pillar to windshield frame screw size? Spridgets 2
J Windshield question pt.2: Why not cut the frame? Spridgets 9
sjuengst Securing the top of the windshield frame Austin Healey 17
doates Spitfire Spitfire Windshield Frame Header Triumph 5
I Stripped screws in Bugeye windshield frame Spridgets 10
A 76 MIDGET WINDSHIELD SEAL FRAME TO BODY Spridgets 13
I TR6 TR6 windshield frame bent? Triumph 8
D TR6 TR6-windshield frame to bady sealer Triumph 3
G Side screen windshield frame polish? Triumph 6
Jim_Gruber Pics of Windshield Seal to Vent Window Frame Spridgets 7
Brosky Under windshield frame and final prep for paint Triumph 6
bighealeysource Rubber seal on windshield frame of BT7 Austin Healey 0
ronzet MGA Windshield Frame creeping MGA MG 20
M TR2/3/3A TR3 Windshield Frame Triumph 2
kyreb1862 Powder Coating A Windshield Frame MG 7
7 Windshield Sideposts/frame refinisihng MG 22
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
B Bugeye Windshield Frame Coating? Spridgets 2
B Windshield Frame Spridgets 14
rchakr Windshield Frame Paint Triumph 13
Bill Redd Rubber strip under windshield frame Triumph 4
R MGB WANTED,windshield &frame for mgb MG 22
Bill Redd Windshield frame to body Triumph 8
H Windshield frame in MG 13
Ed_K BJ8 windshield frame to scuttle gasket fun ! Austin Healey 10
Ed_K Installing the windshield frame to cowl seal ? Austin Healey 6
M TR6 Windshield Frame Color, TR6 Triumph 7
jerryrosa Windshield Frame MG 26
R Removing 66 BJ8 Windshield frame Austin Healey 23
Bill Redd restoring windshield frame Triumph 6
