TR2/3/3A very low oil pressure when TR3a is warmed up
2billydavies
Hi everyone.... just wanted to bounce something off of you all, maybe you can help.
My TR3a runs perfectly (finally) and I really don't have any issues at all anymore. But the oil pressure concerns me a bit, and for the life of me I can't remember if it was doing this
before I did my engine rebuild. I don't recall it... but that was 2 years ago since my rebuild.
Basically, the oil pressure drops to almost 0 when the car is completely warmed up. Once started, it easily pushes past 50 on the gauge (original gauge, original lines, etc).
For the first 10 minutes, it fluctuates between 30 and 50.... sometimes a little higher if i'm under load and getting up to speed.
However, once completely warmed up to running temperature.... the oil pressure just drops like a brick. Sometimes it's so close to zero I want to pull over.
It sounds fine. It runs great.... but why does it do this? Is the engine getting any oil? That's my concern. I keep thinking its the grade of oil I use.... which is 10W30. I live in Florida, so its
warm all year round.
When I did the engine rebuild, I inspected the oil pump. Absolutely nothing looked out of whack... quite honestly it looked brand new. Could I be missing something?
Thanks for any input ya'll might have!
Billy
TR3driver
Great Pumpkin - R.I.P
Sure sounds like something got overlooked. Cam bearings changed? Rod & main clearances checked? Bushing for the oil pump shaft? Did the old bearings look oil-starved?
10W30 should be OK this time of year. Is the problem the same right after you change the oil? Have you tried heavier oil to see what happens?
Have you tried a different oil pressure gauge? What happens if you loosen a fitting (like the banjo at the oil filter head) with the engine hot?
Normally, my suggestion is to leave the oil pressure relief valve alone, but if you have verified the lack of oil pressure, it's probably worth pulling the valve apart to be sure the spring isn't broken, no FOD in the valve seat or damage to the ball, etc.
BTW, an old worn out engine (like mine) will clatter with no oil pressure, but a nice fresh engine won't. It will run just fine, right up until you hear that awful screech of a welded bearing. IMO anything less than 10 psi per 1000 rpm is time to call a flatbed.
CJD
Could be the oil bypass valve is stuck open. After that, it's gotta be internal...so long as your gage is connected and reading properly.
2billydavies
2billydavies
hmmm...... i'm going to start checking all of those you listed. I have not tried any different oil gauge at all. it's the original, I thought it was working OK but im really starting to wonder. Yes, it did the same thing after an oil change. I just did that about two weeks ago hoping for different results, but here I am. I was thinking that maybe I need to try a different weight of oil but everyone I've talked told me 10W30 is fine and that's what a ton of people use.
I'm going to take a look at all of your suggestions. I'm finding it hard to believe this thing is pumping oil around.... or it just stops when the car is warmed up (which is why i keep thinking maybe I need a heavier oil). But I can tell you one thing for certain: i'm not interested in rebuilding this engine again right at the moment. lol. thanks a ton guys... gonna get back under the hood.
M_Pied_Lourd
Check to make sure your distributor is installed properly and that it is all the way down in its clamping mechanism.
Cheers
Tush
LarryK
What type of filter are you using. If it is adapted to a spin on, might try a different filter, as the bypass could be stuck.
2billydavies
2billydavies
I'm using a FRAM spin-on. It's pretty much been the same filter/adapter for the past 25 years. When you say oil bypass, what exactly are you referring to? I just drove it 20 miles round trip to my daughter's soccer practice. Ran absolutely perfectly... but the oil pressure is really scaring me. It hovered right around 10 psi (first line on the original gauge after 0). When I give it gas, it slowly raises but never went past 30psi.... I"m going to park her and take a look at all of your suggestions above. The distributor is definitely in all the way and the little key on the end of it is in correctly. Other than that, I guess i'll start with all of the suggestions above. Does anyone have any suggestions on a heavier weight motor oil? I'm using 10W30 now.... I know the manual says something like 20W50 (or something like that) but at the Auto Zone near me that's motorcycle oil. Is that the same thing?? (clearly not an oil expert here, lo). Anyways, thanks everyone. This car wouldn't even be running if it weren't for this forum.
mallard
Do you have an external cylinder oil feed line on the car, if yes try it with it off.
TR3driver
Autozone should have Valvoline VR1 "racing" oil in 20W50, which is a good choice IMO. (Also what I use in my TR3.) It has the higher level of ZDDP, which many say is important for our old flat tappet engines.
But the owners manual calls for 30 weight at temps to 70F, and only 40 weight above that. So the 20W50 shouldn't be needed unless the engine is well worn.
If the bypass valve in the spin-on were stuck closed, and the filter was clogged, then the bypass in the filter head would open. Borders on impossible for either of them to stick closed, let alone both of them, unless you've been using superglue instead of oil.
But, the gauge pickup is on the inlet side anyway, so it would still show pressure even if both valves were stuck and the engine being starved.
LarryK
The fram filters have a built in by-pass. Try putting another filter on or a different brand. This is since your last change. Filter $5, engine $2K. I have o be careful of brand dissing but have had this numerous times, now I use a Wix or Mann or Cooper. Just sayin!
CJD
50W oil will raise the pressure...but 30w in a newly rebuilt motor should not result in pressure that low. In a well worn motor 50W will bring the pressure back up until a rebuild. You have something else going on, though.
TBU_Triumph
Hi Billy,
I can understand your concern and desire to address this. You have spent a lot of time and money getting to this point.
My suggestion is that you need to take a closer look at the oil pump. Remember that pressure is essentially the result of resistance to flow. If you do not have good flow you will not develop pressure.
Your description states that you have acceptable pressure when things are cold but it drops significantly when warm.
In your original post you stated that you inspected the oil pump and everything looked fine.
  • Did your measure the 3 key clearances (inner to outer rotor, rotor to housing, and rotor end clearance)?
  • Were there any wear patterns on the end plate?
  • Was a gasket used when the pump was re-installed?
My experience is that pump clearances are critical. Larger clearances allow oil to bypass within the pump especially after the oil has thinned as it gets hotter. Pump performance will drop even as clearances wear the upper limits.
Think of this example. In a TR4 the maximum allowable rotor end clearance is 004". If the actual clearance is .006" the area open to allow end rotor bypass has increase 50%! In the world of hydraulic pumps that can be a big difference. Add to this that the other clearances will probably be as worn and there is a lot of opportunity for bypass in the pump.
I know it is a pain getting to the oil pump on an installed engine but the cost of not doing it can be worse.
Good luck and keep us posted.
Rusty
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
angelfj1 TR6 Very Low Mileage TR6 on Ebay Triumph 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Bayless The very simple rotisserie Spridgets 3
G TR4/4A Flasher Unit...VERY hot Triumph 10
R Very Difficult cold weather starting problems! Austin Healey 21
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
drambuie The nasty boy Healey version may very well be more true to the original intent! Austin Healey 14
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
andrea Very strange austin healey 3.9 Austin Healey 5
P gearbox shifts very badly Austin Healey 7
T TR2/3/3A Air dam seems to be working very well Triumph 5
W Very respectable restoration Spridgets 9
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
tinman58 TR5/TR250 Very stiff rear end Triumph 27
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
drooartz MGB Sometimes I'm very proud of my work... MG 6
John Turney UPDATE: Up-date on a Very Expensive Healey Austin Healey 8
D BT7 Hard top back window that is very cloudy Austin Healey 5
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
tr7andtvr Very Disappointed with Lotus at Indy 500 Lotus 13
swift6 A very wild morning drive... Triumph 34
C One very cool Allard Other British Cars 2
C A very pretty little Elva MkVII Racing 1
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
JPSmit Very cool rat rod! Other Cars 3
C The Story of a Very Special Jaguar Racecar Jaguar 2
JPSmit Need a MOWOG and very confused Spridgets 13
C Very nice Triumph-Powered TVR 2200 Special Racing 9
J Anyone interested in very original 1958 Bugeye? Spridgets 1
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
V Very nice Jensen Healey on eBay Other British Cars 10
14dna Very Sad Sight Spotted 0
