HELP: Identifying Chasiss and Engines
JimLaney
I have two Sprite tubs and three engines among boxes of parts - all disassembled bysomeone else 15 years ago.
On one set there is a number tag on the firewall but no number on the block, on the other there is no number on the firewall and one of the engines has a numberplate loosely wired to the starter hole in the backplate.
Are there some telltale signs that would identify the body?
I was told that the two are 1966 and 1967 so I was hoping that I might have a 1275 engine.
Since they both have roll up windows, I'm assuming they are at least MKIII's.
Knowing that I may have misread the numbers; the tub number looked like HAN 8L/155368 and the engine tag was 10CC-D[A]-H 43394
These numbers don't seem to fit into the table on pg 10 of Bristow's book (Restoring Sprites and Midgets)
Any help in identification is greatly appreciated.
Bayless
I believe the HAN 8... would be a Mk III and the 10CC would be a 1098 which would be consistent. All the earlier engines had removable covers in the block to access the valve lifters. The 1275 was solid cast iron with no access.
SaxMan
HAN9 is a Mark IV Sprite, so HAN8 is definitely a Mark III.
Randyz
It's pretty easy to identify these things, if you know what to look for. If both tubs have roll-up windows, they are either Sprite MkIII/Midget MkII (1098) or Sprite MkIV/Midget MkIII (1275). The later would have a raised lip around an extended rear cockpit opening. The 948/1098 engines have removable tappet covers on the side of the block. The 1275 engines do not have removable covers.
JimLaney
JimLaney
Thanks to all for the help.
One chasiss has no tag as the previous start on restore stipped the body to bare and began a repaint.
Some of the "new parts" (suspension including rebuilt rear end) installed were put on the body about 12-15 years ago...hence, rust patina and no fluids in anything.
Thanks again for the pointers.
JimLaney
JimLaney
the raised lip around the rear of the cockpit opening is not there so these are definetly MK III's - Thanks for that particular id info!
nomad
10CC is the big crank engine that would be fitted to the Mk3 Sprite or Mk2 Midget. The earlier engine was the 10CG. 10CC is rated at 59hp.
Just to add to the morass.
Kurt.
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
J help identifying my transmission... Triumph 8
B Please help identifying top bows MG 5
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
C help identifying hard top Spridgets 1
Gliderman8 TR6 Help with identifying my TR6 heads Triumph 3
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
vping Need help Identifying an OD Transmission MG 3
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
