TR4/4A Which seat frame do I have?
Tim Tucker
Hi Guys! I've stripped my passenger seat down and would really appreciate your knowledge on what frame I have. My TR4 was built 10/23/1962, but my seat covers (per Moss pictures) are from a 4a. Are my frames from a 4a? The front of the passenger side has a small 'dent' in the lower rail that the driver's side doesn't appear to have (driver side is still covered). Am I correct that my lower frame shouldn't be 'dented'? Any ideas what the small chrome 'zerk' looking item is on the inboard side of the passenger seat frame? Thanks in advance for any help!
seat frame (post media blast) (1).jpgseat frame (post media blast) (2).jpgseat frame (post media blast) (3).jpgseat frame (post media blast) (4).jpgWhat is This.jpg
I hated to revive this old thread...https://www.britishcarforum.com/bcf/showthread.php?77715-tr4-tr4a-seat-frames
TomMull
I'm not that familiar with the 4A seats but that certainly does not appear to be an early TR4 seat. Tom
TR3driver
Great Pumpkin - R.I.P
I'm not either, but they sure do look like the illustration in the 4A SPC
Rut
They look identical to my TR4a seat frames.
Rut
Those are TR4a frames. A 62 TR 4 will have seat frames that look very close to TR3 frames. Main difference is seat pan has a dip in it. I think I may have a set left for pictures but will have to check.
Marv
Popeye
Bronze
I can't contribute to the conversation, as my seats are still under the old, incorrect, covers. But thanks to the details here, I will look here when I start to work on them!
I just wanted to say thank you for the post and discussion!
TR3driver
Thanks Randall! My spare parts PDF file ends with the BB overdrive plate...I've never seen the BG plate...again, Thanks!
Tim
EDIT: The dime finally dropped, if you have overdrive on BB then you're probably looking at a TR4 SPC rather than the 4A SPC. BB Overdrive is indeed the last plate in the TR4 version; but the TR4A version has overdrive details on plate BK.
FWIW Here's the TR4 seats illustration
Tim Tucker
Tim Tucker
Richard: Thanks! I found it late last night as a PDF on "tr4a.weebly". It's going to be my instruction manual. These seats were in my car when I bought it 9-1-1981. I'm sticking with them since the covers are in good enough shape to use as patterns. The foam was disintegrating daily. Always needed to vacuum the car. I owe a big thanks to Alan John Turner for documenting their TR4a seat effort!
Tim
Rut
Marv
Btw, these are the seat I bought from you!
Rut
TR3driver
Thanks Randall! I have the spare parts PDF that's all over the internet. It has two page 126s (# at bottom NOT PDF page) and is missing page 127. The last numbered page is 130. Here is a link to my bookmarked version.
https://tidentenn.com/pdf/TR4 Spare Parts Catalogue (bookmarked-p127 missing).pdf
Do you happen to have a page with 127 at the bottom...:smile:
Thanks again,
Tim
Just to be clear, that's the TR4 SPC, not the 4A. Different books. I have page 127, but it's from the 2nd edition while the PDF you linked to is the first edition. Might not be exactly the same information (but page 128 appears to be the same so maybe 127 is as well).
Here's a high rez scan, let me know if you need a different form.
https://drive.google.com/file/d/0B2H2NJt34OffOEIwME90aWE3Tm8/view?usp=sharing
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
Healey Nut Seat Base Frame Position Austin Healey 4
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
R Seat frame alignment with seat back Austin Healey 18
pbraun Bugeye seat back frame Spridgets 13
Popeye TR4/4A Seat frame - rust "repair"? Triumph 1
B TR3 seat frame issue Restoration & Tools 2
Shealey What does the fastener on the seat frame look like Spridgets 3
T MGA MGA Seat Question - frame bolt assembly pictures MG 4
T MGA Please, Tony, do find an MGA seat frame for me.... MG 3
T MGA MGA seat frame bottom - anyone have a spare? MG 3
J CP seat built on CF/CR frame - is it possible? Triumph 1
Rob_P How would you treat this seat frame? MG 9
AUSMHLY Seat bottom frame - painted or vinyl rapped Austin Healey 3
KLUTZ Wedge Good price for a TR7 seat frame? Triumph 4
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
