TR2/3/3A Moss Replacement front disc pads
croz
1960 TR3A - front brake pad replacement.
I purchased part number 585-502 from Moss and they are different form the ones that I am replacing.
In the image below the old pad is on the left and the new one is on the right.
Comments??
Thanks,
Steve
P1030745 crop.jpg :feedback:
Geo Hahn
Hmmm - looks like you may have TR3B(TCF) / late TR4 calipers if the pads on the left are what were in there.
Looking at this illustration - are your calipers type B or type C? Do they secure the pads with pins or with a retaining plate?
I think your car would originally have had type B but perhaps someone put type C calipers on as a replacement.
TR3driver
Great Pumpkin - R.I.P
There is a note in Piggott that some "very late" 3As were fitted with the later type brakes. He only mentions the brake rotors, but the calipers would have gone along with them. "However it has not so far proved possible to identify any change point." probably means there was no 'clean' change point (as with so many other changes).
Up to you, of course, but I'd just return them and buy the TR4 components. If you do want to swap back to the earlier calipers, you should also check that the rotors & caliper mounting brackets are the earlier type.
croz
croz
Sorry about the late reply. My calipers are indeed the "C" Type. Thanks for pointing out the image. Pins rather than clamping plate. I should have seen that.:confuse:
A previous owner must have upgraded.
Thanks for the reply's.
T Anyone used Moss front floor pan replacement panel Spridgets 2
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Willie_P TR4/4A Moss Replacement Sheetmetal - TR4 - any good? Triumph 6
J MOSS Replacement master cylinder Spridgets 13
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
C Expereince with Moss motors replacement body panels MG 13
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
