Results 1 to 4 of 4
Thread: 1956 MGA negative ground, True Spark Ignition distributor
Discussions of MG Sports Cars
  1. #1
    Join Date
    Jun 2015
    Location
    dallas, tx
    Posts
    80
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    message removed
  2. #2
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,601
    Thanks Thanks Given
    83
    89
    Thanked in
    Re: 1956 MGA negative ground, True Spark Ignition distributor
    Whether the car is wired positive or negative ground, that white wire ~should~ be supply voltage. That white wire is NOT coming from the generator. It comes from the ignition switch.
    To further muddy the water, if the coil is original to 1956 you need to reverse the connections. If it is a "modern" one (for a negative ground car) you should follow the plus/minus on it..
    We need a bit more info. Is the coil a Lucas pre-68 or a later one? Or even a Lucas one?
    BPNW is not standing in front of the car, disparaging them is unhelpful to say the least.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  3. #3
    Join Date
    Jun 2015
    Location
    dallas, tx
    Posts
    80
    Thanks Thanks Given
    Thanked in
    message removed
  4. #4
    Luke Skywalker Roger's Avatar
    Join Date
    May 2002
    Location
    Richmond,Texas
    Posts
    1,692
    Thanks Thanks Given
    4
    Thanked in
    I tend to agree with Doc.
    Since you misidentified the white wire, incorrectly described where it should go on an "analog" ignition ( whatever that is) and show, with respect, not a lot of knowledge of the subject, I can well imagine that your conversation with the supplier was less than meaningful!
    Roger
    Ancient Briton
    '67 Lotus Elan S3
    '72 Lotus Europa TC
    '05 Lotus Elise
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
