TR6 TR-6 Wheels Wobble & Lift
TR-3rg
Hi,
Does anyone have the factory spec for wobble & lift on a steel TR-6 wheel? I see 3/32" listed in the TR-2 / TR-3 Service Instruction Manual.
Thanks, RG
TR3driver
Great Pumpkin - R.I.P
TR6 workshop manual gives .045" (about 3/64")
T
TR-3rg
Hi Randall,
Thanks for checking. I picked up (4) TR-6 wheels at a junk yard and it looks like (3) are in spec. The forth has .06 for wobble, but its round. Its far better than what I have. I also found a shop that can balance the wheels using the bolt pattern, not the center hole.
Roy
Tybalt
Hi Randall,
Roy
I would think that there are wheel repair outfits in the Baltimore area. You might want to consider taking the wheel in and having it straightened. Any wheel place that knows what they are doing should have no problem getting a steel wheel that is out by ~.06" back to well within spec.
TR3driver
The downside is that straightening it may make it more likely to crack in the future. TR6 wheels are known to be prone to cracking.
Most wheel shops around here won't touch steel wheels any more. Too much risk of being held liable after a broken wheel kills someone.
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W For Sale Wheels for sale Austin Healey Classifieds 1
glemon Wanted TR250 Wheels Triumph Classifieds 1
D MGB BWA Alloy Wheels MG 9
T TR2/3/3A minilite wheels Triumph 5
R Bugeye splined wheels Spridgets 0
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
P TR5/TR250 Wire wheels width Triumph 8
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Wire Wheels and Air Leak Austin Healey 16
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
Y MGB Aftermarket wheels MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
R MGA wheels MG 10
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
F TR6 Wheels and tires Triumph 10
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M TR6 Center cap for wheels Triumph 2
C Replacement wheels Rover / Land Rover 1
B Refinishing Minilite Magnesium wheels Restoration & Tools 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Recommendation on wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
DerekJ Original steering wheels Austin Healey 1
B TR2/3/3A Tubes in steel wheels? Triumph 18
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
