TR4/4A Mazda Wheels
mcmillal
Hi,
Is anyone running those older, 1990ish, Mazda Miata wheels on their TR4? I think they're 14x5.5 and was wondering if they will fit and look.
..........Alex
TR3driver
Great Pumpkin - R.I.P
Check carefully before you try it. ISTR the Miata wheels have a metric bolt circle that is almost, but not quite, the same.
martx-5
The early Miata wheels have a 4x100 bolt pattern and the TRs have a 4x114 (4.5") bolt pattern.
glemon
The bolt pattern is pretty common with imports from the 90s and such, but most wheels don't have the right offset. I suppose you could, but I probably wouldn't put 14" wheels on a TR built for 15s. Your tire diameter will be too small, and the wheel itself might interfere with suspensio components with the smaller diameter on the inner lip of the wheel.
groupdeville
There are 15" Miata wheels that also have the 4-bolt pattern, but that doesn't solve potential offset problems or hub-clearance issues in trying to use them on a TR.
Just out of perversity, there are also Miata-people who have looked into putting knock-off Dunlop-style wire wheels on an MX-5.
Tybalt
The 15" NA and NB generation Miata wheel still has that 4 x 100 bolt pattern, the NC went to a 5 bolt pattern while the ND returned back to the 4 x 100. If you want to talk using Mazda wheels, you need to think in terms of some different models such as the RX-7 and even then you have to be careful. The earliest FA and some FB model RX-7s used a 4 x 110 bolt pattern wheel, while later FBs used the same 4 x 114 as the the TR series. That 4mm is just enough to mess you up. It'll look right if you don't check, but that 4mm will keep early Rx-7 wheels from being readily used on a TR. You might also think in terms of looking at Datsun/Nissan 240Z/260Z/280Z/280ZX wheels as they share the same bolt pattern as the TRs. I've long thought that if you can find them, a set of wheels from a 1981 280ZX Turbo would look rather sharp on a TR, but then it may just be me.
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
rjc157 TR6 Mazda seats Triumph 3
Steve P. Formula Mazda open wheel race car Racing 0
3798j Mazda's New MX5RF Other Cars 2
D Mazda 3 vs Ford Focus Other Cars 5
JPSmit Tonight's question -Mazda misfire Other Cars 2
AngliaGT Mazda RX3 Wagon Spotted 0
Sherlock 2001/03 Mazda 3 Other Cars 8
JPSmit Mazda 5 bearing question Other Cars 1
JPSmit Mazda 6 question Other Cars 9
NutmegCT Mazda Protege loses high end power Other Cars 5
JPSmit Mazda 6 tires Other Cars 3
John_Mc Mazda Stereo woes... Other Cars 2
S Mazda RX8 Seats Triumph 16
Steve P. Formula Mazda Race cars; anyone know about these? Other Cars 2
NutmegCT Mazda fun - CV joint? Other Cars 6
K MGB 1970 MGB w Mazda Rotary done right! MG 13
R6MGS Europa with Mazda Rotary engine Lotus 69
Dave Russell Battery Experiment - Mazda/Healey Austin Healey 5
S mazda engine swap MG 5
Simon TR4a New Mazda MX3 Other Cars 4
G mazda 3 2005 accessorized[new] OR 2006 basic[new]? Other Cars 2
Basil Mazda RX-8 Other Cars 11
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W For Sale Wheels for sale Austin Healey Classifieds 1
glemon Wanted TR250 Wheels Triumph Classifieds 1
D MGB BWA Alloy Wheels MG 9
T TR2/3/3A minilite wheels Triumph 5
R Bugeye splined wheels Spridgets 0
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
P TR5/TR250 Wire wheels width Triumph 8
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
