Ignition timing with Pertronix Ignitor and strobe light
Lutz Kramer
One year ago I put a Pertronix Ignitor-I Kit #ML-161 in a Mallory Distributor of my AH 3000 MK III Phase 2.
When I put it in, I did the timing manually, because it couldn’t be done with a timing light since I couldn‘t reach the appropriate paramaters given by the manual, which are 15° BTDC in idle and about 38° at about 4500 rpm. Whenever I came close to 15° the engine stalled. When I checked the timing with the strobe light I got and still get the following indications: 40° BTDC at idle and about 60-70° BTDC at 4500 rpm, which is of course way off. I can’t even believe that the engine is running with those settings.
What so ever the car has been running without any problems since then.
I know the words: „Never touch a running system!“. Nevertheless I want to have the engine running in accordance with the right parameters and of course would like to find out the reasons for this strange phenomenon.
So, I checked the mark for TDC on the pulley while the rotor is pointing at the #1 plug wire. Everything is just perfect! In addition to that, the piston is in combustion stroke and the distributor is indexed correctly and not 180° off.
Now, can anybody tell me what‘s wrong here?
I called Pertronix here in Germany and they absolutely have no idea.
The only thing I can think of would be that the coil ist producing a certain amount of power which is strong enough to create a spark while it‘s not strong enough to activate the strobe. This may be done by a second flow of power that follows the frist one right after. So the strobe would be lighting the 40° mark while the spark is already history???
I know it sounds strange, but has anybody any idea?
Lutz Kramer
Lutz Kramer
Of course it could be a poor Strobe light. But I forgot to mention that I already had tried another timing light of a friend of mine of another manufacturer. Unfotunately with the same results!
Keoke
Well another Wild Arse Guess:
The common element here is your car so maybe the car's ignition radiation upsets the digital timing lights.???
Roger
Bronze
Simple things first. Are you sure your pulley correctly shows TDC? Can you check the piston position?
Lutz Kramer
Lutz Kramer
Roger, I checked TDC on the pulley with the position of the piston and the pulley indeed is exactly showing TDC.
Something else I found is that the distance between the magnetic sleeve and the module on the basic plate is almost 0 mm while the guys of Pertronix Germany say it should be betwenn 0.5 and 1.2 mm. Could this may be cause the phanomenon described?
Keoke
Well it just might be as your repetitive TEST RESULTS seem to emulate an incorrect dwell time???
Lutz Kramer
Lutz Kramer
Yesterday, I pulled the distributor and put it on a bench for testing. Connceted the battery to the module and hooked up a voltmeter. Then I turned the rotor and it just worked fine at all 6 cylinder positions. Twell time also seemed to be ok.
Then I put it back in, cranked the engine and best run in idle was again at 45° BTDC!? When I turned the dizzy towards 15° BTDC the engine stalled already at 20°. So, still the same problem.
May be I should bench test the ignition system together with the coil and see whether there is a time difference between the spark and the time the strobe light fires? That would portend to a coil problem.
Any other idea is welcome!
johnea
Why don't you replace the Petronix with the standard contact breaker set and see if you can get her to 15 degrees at idle?
Jim 58 BN6
Sounds to me like you need to index the rotor? Are you sure you are on the #1 wire?
Yes, that's a good thought. Google "rotor phasing". I think MSD has videos that explain this. Don't know if Pertronix has this issue, but the MSD on my Dad's Cobra replica did, and I did the procedure for him. Made a big difference.
If the car seems to be running OK, then maybe the spark is occurring at about the correct time, but there could be something causing the timing light to trigger late(???). If you are using newer, "high-tech" lights, maybe find an older, less fancy one, and see if it shows a different advance. My original timing light from the '70's doesn't have an inductive pick-up. You have to insert a springy thing that fits snugly on the spark plug cap, and into the wire boot, then attach an alligator clip to the springy thing. Maybe the inductive pick-up, and the type of plug wires, and some kind of RF interference are messing with the timing light's measurement. Just a Wild-Assed-Guess! GL, Jim
Jim 58 BN6
Another thought (and that can be dangerous!): Is the cam timing off (or a slack chain)? That COULD cause something like this. I'm thinking it might be off only a tooth or two. This is probably a bit of a reach, but might be a possibility. If you remove the valve cover, use a dial gauge and put some marks on the front pulley/damper. There should be valve opening, closing and lift specs that might tell you if this is the trouble. A decent repair manual might describe the procedure. Jim
Lutz Kramer
Lutz Kramer
Good Ideas Jim!
I used to have an old Bosch timing light, that had to be plugged within the spark plug and the plug wire, like you mentioned. Unfortunately it's lost. But anyhow will try to find one. The other possibility would be to visit a Bosch station here in Germany. They usually have oscilloscopes which can be used to find out what is going on in plug wire #1.
Lutz Kramer
Lutz Kramer
Jim, indeed the cam timing might be a problem, since I had changed the chain last year. But I'm pretty sure I didn't mess up the timing. I checked everything several times before I closed the chain cover again. But you never know!?
Lutz Kramer
Lutz Kramer
Chris I'm pretty sure to be on #1 wire!
But what I will do is putting back my old contact assembly like John said. This way I can find out, whether there is something wrong with the coil or the plug wires. In case the timing light would show 15° again the problem would be more or less the Pertronix.
Jim 58 BN6
I was almost bit by a mistimed cam. When I replaced the gear/chain assembly, it looked correct, until I started to install the chain tensioner on the slack side of the assembly. As the chain's slack tensioned, the cam gear rotated. Fortunately, I caught it, and aligned the assembly again with the tight side of the chain such that when the tensioner moved into the slack side, the gears stayed in alignment.
My favorite (NOT!) mistake, which happened fairly recently on my Ford appliance car, was installing one front brake pad backwards, so that the metal side was against the rotor! Fortunately, it was VERY apparent the first time I applied the brakes. Guess I was in a hurry, or just suffering from what an old boss called "Cranial Rectumitis". BTW, I've been working on cars for 40+ years, so I must be an expert mechanic! :eek:
The Bosch station's 'scope might tell you a lot. That would be my first stop, if I couldn't find an old-school timing light, and replacing the Petronix with the original points assembly didn't change things. Jim
Lutz Kramer
Lutz Kramer
As far as I remember I did the timing of the chain in accordance with the manual by counting the chain links between certain marks on the cam gear and the crank gear on the opposite side of the tensioner, but I can't remember the number of links anymore. As soon as the tensioner starts to work it is true that the cam gear may be moved but also the crank gear is moved without any lack since the crank gear is pulling at the chain on the non slack side which is therefore always taut. So as long as one counts the right amount of chain links, the timing should be perfect.
Lutz Kramer
Lutz Kramer
Today I pulled the Pertronix and put in the old Mallory twin contact plate. Leaving the dizzy at the same position as before the timing light pointed at 35° BTDC at idle instead of 45° with the Pertronix but still far off from what is supposed to be normal (15°).
I believe the next step is to visit Bosch!
Roger
Bronze
Clearly the car is not running with such exaggerated advance, so if your pulley is correct, something is wrong with your measuring.
So changing parts on the car is probably not going to fix It! The Mallory plate being different from the Pertronix is not so surprising.
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
R Pertronix ignition and static timing MG 22
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Ignition timing question Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
Bruce Bowker ignition timing mark Austin Healey 5
glemon Never Assume [Ignition Timing] MG 1
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
M Another Ignition Timing Question Austin Healey 8
AltaKnight Ignition timing Triumph 19
H Ignition timing Austin Healey 1
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
D BJ 8 Ignition timing Austin Healey 5
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
H Ignition timing and pinging Austin Healey 1
txtr3 basic ignition timing question Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
