TR4/4A Idle spring?
Marla
The 1964 Tr4 was idling a bit high so I looked at the screw to adjust and it did drop the idle but the return spring will not bring the metal to rest where it is suppose to...I circled in the photo... the nut etc...does anyone know how I can get this spring to rest against the bottom of the idle screw?...I tried to adjust the nut next to the spring but it will not go tight...maybe the nut is stripped?...right now with the return spring so far away from the metal bracket someone has to physically hold the part down so it rest on the idle screw because the car runs way too fast...anyway I hope the photo explains the problem and I am not babbling...Marla
poolboy
Loosen the connection between the 2 carbs that joins the throttle shafts together... See if that allows the tip of idle speed screw to come to rest on the pad....That btw, is what you do when synchronizing the carbs...make them independent by loosening the throttle shaft coupling , adjust each individually until they 'balance' in sync, then reunite the throttle shafts.
The nut on the end throttle shaft has nothing to do with what you are trying to do.
Mickey Richaud
:iagree:
Almost certainly the issue. Should clear it up.
TR3driver
Great Pumpkin - R.I.P
I agree, except that nut is what holds the lever to the shaft. If the nut won't tighten to the shaft, you may have a problem there that needs to be addressed. Probably have to replace the throttle shaft, which is a fairly complicated operation.
Marla
Marla
The nut does tighten to the shaft...so that is one headache out of the way...thank you...Marla
Geo Hahn
My usual sequence is to loosen one nut/bolt on one of those 'accordion' connectors and then balance the air flow into the carbs and set the idle using one of the methods described in the manual. Center of photo (wrong car but same connector):
At that point the connector is tightened. Further (slight) idle adjustments can be made by turning the idle screws an equal amount (to keep things more or less in balance).
The balance is not a supper-critical adjustment IMO because there is a pretty large balance tube in the manifold connecting the front and rear halves. Also, I think the rear carb often lags the front carb as the throttle is opened up.
Marla
Marla
Yowza...the advice one get's from this forum is priceless...did what was suggested and it went wonderfully...you guys rock!!!...Marla
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
crispy Idle Speed Variation Austin Healey 19
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S Can’t get idle speed below 1300 RPM Austin Healey 28
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
NutmegCT T-Series MG TD idle speed? MG 12
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
wkilleffer MGB Air leaks and fast idle speed MG 11
D 69 E Type High Idle Jaguar 9
K TR2/3/3A Mild street cam and Idle? Triumph 13
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
J MGB Project car done: idle variable MG 2
J SU HD6 - Slow Idle Screw Austin Healey 13
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
S Idle falls until car stalls Austin Healey 10
steveg HD8 high idle aggravation Austin Healey 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
Geo Hahn TR4/4A Stumble Off Idle When Hot Triumph 4
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
B Fast Idle Spridgets 7
AUSMHLY Idle does not stay constant, why? Austin Healey 22
