Hot Volvo
HealeyRick
My wife and I were touring the Maritimes when I stopped for gas at an Irving station in Truro, NB. Saw a nice looking Volvo 140, lowered, with some really big brakes and towing a boat. Wondered what other mods were done, until he started it up and I heard the distinctive V8 rumble and saw twin pipes out the back as he left the station. Sounded really nice.
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
F Hot Ignition Coil Austin Healey 6
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
7 General TR Hot rod Triumph 0
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
steveg Healey hot weather driving observations Austin Healey 2
bugedd Hot legs and hood top bow Spridgets 15
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
N Jet Hot??? Spridgets 13
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
S Hot tip: seal for fuel tank sender Austin Healey 9
aeronca65t General TR Kastner Cup video walkthrough of hot pits Triumph 1
D Getting hot in the car [AH3000mk3] Austin Healey 6
