MGB-GT distribution of problems
Sopwith_Camel
ok yes you should tackle one job at a time but ....
ok so I'm doing a RHD to LHD Converstion so everything under the dash has un plugged.
+ new gas tank and distributer.
Gas tank is painted and went in ok I may have cross threaded the brass pipe.... no leaks yet
so I have hooked up the battery and some how smoked the Heater fan oh new heater matrix so that was all out and banged around a bit.
Now I'm trying to hook up a 123Ignition brand Distributer I like the one in my jag. it says hook up just the red to the coil only Check turn on ignition and twist till the LEDs are out. no LEDs .... bright sunlight doesn't help, sun sets not till 11:00. .... but thats not why I'm writing when i turn the ignition on the Tachometer hops up like .... well I will spare you the colourful medifore .. it hops to attention. why? there is only one way to wire the tach, the speacle connectors make sure of that. ..... oh could it be because i have an earlier dash and harness? I have tried plugging in the black wire from the new Distributer to the coil the tach still hops up. no i have not put anything to the crank position or even hooked up the coil yet.
ahhhhh.
Sopwith_Camel
Sopwith_Camel
toast ok the Distributer web site says that it won't work with RVI smiths Tachs.
dose that mean the car won't run or that i just have an non working Tach?
this might start to explain the issue with my midgets tach and the malory
but strange the Jag is smiths and it just dropped in no problem.
can i take the white wire that goes inane then out of the tach and just connect those two ends and bi pass the tach ?
Sopwith_Camel
Sopwith_Camel
ok im wire away from the car starting or smoking 250 bucks.
I'm doing the last diagram i have the blue wire in, but do i hook up the red or the black wire from the tach to the Distributer.
it looks like the diagram is from "enjoying mg" october 2012 any one have it in colour?
Z Bosch Fuel Distribution Unit TVR 5
Z Bosch Fuel Distribution Unit TVR 2
H Has anyone changed their electrical distribution? Austin Healey 7
T TR2/3/3A TR3A Brake distribution block Triumph 12
H Healey 2009 Concours Guidelines distribution Austin Healey 8
coldplugs New Mini - Sales & Distribution info British Motor Corp 5
Carlbanan56 MGB High beam problems MG 3
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
B log in problems FORUM Navigation Questions 6
PAUL161 BCF Password Problems FORUM Navigation Questions 10
H MGB Starting Problems MG 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
L TR2/3/3A Shifting problems Triumph 4
S TR2/3/3A problems getting the engine to run correct Triumph 21
P Wedge Starting problems TR8 Triumph 3
C Autocrossing a classic Mini problems Other British Cars 2
KVH Rattle Can Problems Restoration & Tools 5
P TR6 TR6 Horn Relay Problems Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Cold Start Problems BN7 Austin Healey 21
AngliaGT Fuel Pump Problems Spridgets 2
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
T Overdrive Problems Austin Healey 18
W Tach wiring problems Jaguar 12
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
J TR2/3/3A caged nuts problems Triumph 12
N Fuel gauge problems? Spridgets 9
H Overdrive Problems Austin Healey 9
H Overdrive Problems Austin Healey 0
TulsaFred Convertible Top Fitting problems Spridgets 29
trotti Shock mount problems Austin Healey 9
G Spitfire Emissions problems Triumph 3
I Bugeye dash light problems Spridgets 9
M Cold start problems Austin Healey 33
JimLaney 1098 stuck lifters problems Spridgets 5
J 100/4 oil gallery problems Austin Healey 0
J OD problems FORUM Navigation Questions 3
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
J Bj8 gearbox problems Austin Healey 9
C Healey BN6 water pump and overheating problems Austin Healey 11
R Very Difficult cold weather starting problems! Austin Healey 21
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
C Windshield Installation problems Austin Healey 6
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
H Continuing clutch problems Austin Healey 10
sim Sprite 58 turn indicator problems Spridgets 10
H Continuing clutch problems Austin Healey 7
H Problems with Girling master cylinder Austin Healey 8
DugMoney Shutoff problems Spridgets 7
