Got_All_4
I only have a wiring diagram for a TR4 for the overdrive wiring. What gauge are the wires coming off the ignition switch and AMP meter that go into the relay and on a TR3 does the brown wire get it's power from the amp meter? I have 16 gauge and started to wire mine and noticed that the OEM yellow purple wire is probably 10 gauge so I got concerned about my 16 gauge wire. Also how are the wires routed from the transmission to the relay? I also was planning to connect the white wire to the + side of the starter switch as the ignition switch terminal already has 3 wires in it. Any problem here? This is a A type.
Thought I was going to wire up my overdrive tonight but went to get the relay out of the donor TR6 and there was none. They must have wired it directly through the switch. Anyway is there a aftermarket option? Thanks
