Results 1 to 10 of 10
Thread: Fitting the original tr3 transmission cover over a tr6 overdrive
  1. #1
    Luke Skywalker Got_All_4's Avatar
    Join Date
    Dec 2004
    Location
    NEOHIO
    Posts
    1,553
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    I remember this topic before and tried to do a search with no success. The issue is that the transmission is a inch longer then the TR3 original so the speedo cable doesn't line up with the rubber boot so I used a 90 degree adapter and that solved that problem. But now the new unintentional consequence is that the adapter protrudes over the mounting flange. What kinda fix am I looking at.
  2. #2
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,875
    Thanks Thanks Given
    3
    Thanked in
    Re: Fitting the original tr3 transmission cover over a tr6 overdrive
    Hmm - are you sure you have bad interference if you take out the angle drive? If you can massage the cover slightly to fit a straight cable I think you will have one less component to worry about. My 3a has a 4 synchro overdrive box and I don't use an angle drive.
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
  3. #3
    Join Date
    Dec 2004
    Location
    NEOHIO
    Posts
    1,553
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I had to add the angle drive because there was no way to make that sharp of a bend in the cable. It is latterly an inch past the boot and no way to make that kind of a bend without pinching the cable. Now the angle drive will hit and wear on the tranny cover unless there is away to get relief.
  4. #4
    Luke Skywalker sail's Avatar
    Join Date
    May 2007
    Location
    IA
    Posts
    1,990
    Thanks Thanks Given
    6
    Thanked in
    On my 4A I cut a hole in the cover and used a rubber floor plug to give room for the angle drive.
    Richard
    65 tr4a
  5. #5
    Join Date
    Dec 2004
    Location
    NEOHIO
    Posts
    1,553
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    That's a big hole!
  6. #6
    Join Date
    May 2007
    Location
    IA
    Posts
    1,990
    Thanks Thanks Given
    6
    Thanked in
    The 3" hole is about right, maybe some other plug it's been a while. I tried to melt, stretch the plastic tunnel first with no success.
    Richard
    65 tr4a
  7. #7
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    195
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    I need to resurrect this thread... is there a definitive answer on how to cope with the right angle drive jutting out past where the transmission cover fits? Looks like this previous thread came up a 3” hole and grommet.
  8. #8
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    195
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    Or, is it not an issue with that rubber piece that encompasses the parking brake?
  9. #9
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    251
    Thanks Thanks Given
    2
    6
    Thanked in
    The rubber piece in your photo is missing the the part that the cable goes into, if you take away the angle drive it should all line up with the slot in the tunnel cover. I have the TR6 box with A type OD and it is tight but does fit ok.
    Graham
    [SIGPIC][/SIGPIC]
  10. The Following User Says Thank You to Graham H For This Useful Post:
    Jim_Stevens  (12-11-2019)
  11. #10
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,345
    Thanks Thanks Given
    29
    Thanked in
    Like tr4nut said if you get the longer OD cable it should arc through a hole in the frame and fit right at that point and fit nicely.
  12. The Following User Says Thank You to sp53 For This Useful Post:
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
