T-Series lip on bore of td
saltiga
I have had the xpag engine resleeved back to standard, this has left a lip at the bottom , between the new sleeve and the old bore diameter, so small(.030") this has made it impossible to fit the new rings and piston with my ring compressor. As the lip is only .030" would any harm be done if I were to taper this part of the bore to match the old bore size . this then would allow the rings to go into the new bore size, ( the reason I had it resleeved is because the engine had been left out in the rain and damaged the bores beyond any over size rebore. hence back to standard) Or is there another way?? Saltiga
CraigC
Install pistons and rods MINUS the rings from inside crankcase. Push pistons past top of block sufficiently to allow fitting of rings. Install ring compressor and then guide pistons back down into cylinders.
S
saltiga
Thanks for the intelligent reply, Now why did I not think of that!!! So simple, I had all sorts of ingenious ideas, I even asked an MG dealer , no luck there. very impressed. Saltiga
Grantura_MKI
You should be ok, but check the stroke of to piston before fitting the rings. I had the same issue and the lower ring would touch....better safe than sorry later.
Brinkerhoff
I wouldn't hesitate to leave the lower skirt rings ( If the pistons use them) off if they are even close to the step. I've had to do that twice with no regrets.
tosoutherncars HELP! Hub / inner axle seal - metal lip? Spridgets 6
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
SNClocks Master Cylinder Bore Diameter Spridgets 0
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
Rut TR4/4A Master cylinder bore diameters Triumph 2
tinman58 General Tech Cam bearing line bore Triumph 20
Bremer TR4/4A 92mm bore engine pros and cons Triumph 9
K Rough patch inside bore of SU? Triumph 2
dougie Small Bore at Summit Point - Michael Oritt Racing 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
PatGalvin TR2/3/3A TR3 Compression Ratio with larger bore liners? Triumph 5
K TR4/4A TR4A brake MC .70 bore = SP2102 ? Triumph 6
B 89 mm big bore kit Triumph 3
davidb Healey 3000 cylinder bore Austin Healey 25
Hap Waldrop For you small bore lovers Spridgets 45
TR6oldtimer Need a machine shop in N. Calif to bore for cam Triumph 5
Dadandson Cylinder Bore/Hone Spridgets 4
drooartz Clutch slave for 3/4" master bore Spridgets 5
J clutch slave bore size Spridgets 1
J Piston to bore clearance. Austin Healey 23
B MGA MGA Big Bore Exhaust. MG 3
Bruce_B Spec. Needed for 1275 Line-boring - "Housing Bore" Spridgets 13
Bruce_B Line-Bore Question for 1275 Spridgets 0
Shealey Anyone Know master cylinder bore size? Spridgets 15
J clutch master cylinder bore diameter? Triumph 1
ChrisS Max. bore w/ liner Spridgets 3
John_Mc Master Cylinder with oversize bore Triumph 1
Morris Cylinder bore question Spridgets 14
