• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
AH Clutch plate orientation
chris57
Hi. New to this so I hope I'm navigating this site correctly. I have a clutch question. 64 Austin Sprite. The clutch plate is not symetrical. The hub protrudes more in one direction. I don't recall. Does the hub face the engine or the transmission? Thanks for the help.
Mickey Richaud
Welcome, Chris!
This is the forum help site. Post your question over on the "Spridget" section, and you'll get lots of info.
:cheers:
Mickey
Administrator
Boss
Hi, Thank you for the help. Where do I find the spridget section
Click on (Forum) button above. That will take you to the main forum index page where you will see all the forums. Just scan down the list till you see "Sprights" and then click on the link to enter that forum.
C AH Clutch plate orientation Spridgets 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
J TR2/3/3A Dirty clutch driven plate Triumph 5
J TR2/3/3A clutch driven plate Triumph 1
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
KVH TR4/4A Clutch Pressure Plate Wear Triumph 1
K TR4/4A Clutch pressure plate bolt size? Triumph 1
Got_All_4 TR2/3/3A What clutch plate do I use with a J or A type Triumph 1
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
K TR6 The TRF Clutch "Magic Kit" pressure plate? Triumph 1
J New clutch and pressure plate are STIFF! Triumph 9
K TR4/4A Can I fit a TR3 clutch plate&disc in a 4A? Triumph 4
H Accessing clutch plate on Austin Healey 3000 BJ7 Austin Healey 5
W BN2 clutch cover or pressure plate question Austin Healey 2
R Clutch plate stuck to flywheel Triumph 20
tomshobby clutch pressure plate hatched Triumph 6
lbc_newbie Clutch/Pressure plate...which one? Spridgets 12
drooartz Clutch plate, which way? Spridgets 7
davidk Clutch Pressure Plate Question Triumph 9
M TR2/3/3A TR3 Clutch / Pressure Plate Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
J Clutch pressure plate very close to gearbox Spridgets 3
BritCarFan 180mm or 190mm clutch plate diameter? British Motor Corp 1
O Clutch Driven Plate Thickness Triumph 8
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
