Page 9 of 9 FirstFirst ... 56789
Results 161 to 167 of 167
Thread: Starting my Bodywork journey.
  1. #161
    Join Date
    Apr 2017
    Location
    Loyalsock PA
    Posts
    27
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Re: Starting my Bodywork journey.
    Quote Originally Posted by sp53 View Post
    Well I hope these help Dave. In the front the line clips to inside of the frame in a U then goes from side to side like in the pics.
    steve
    Sorry for taking this off course. I see your frame is white. Do you think that is the original color?
  2. #162
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,091
    Thanks Thanks Given
    14
    62
    Thanked in
    Hello SP53
    Thank you.
    That helps.
    David
  3. #163
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,460
    Thanks Thanks Given
    38
    Thanked in
    That is actually primrose yellow and is the original color. I bought the car the frame came from in 1971 and if you look around the forum you will see that the 1958 cars had frames of all different color. The color depended what was left in the paint gun. Later around 59 or 60 they were all black. Not sure about the earlier ones.
  4. #164
    Join Date
    Dec 2015
    Location
    Moseley, VA
    Posts
    35
    Thanks Thanks Given
    Thanked in
    Here are some pictures I took during disassembly. You, and John and Tush, are motivating me to get back to work!!
    fullsizeoutput_fbe.jpgfullsizeoutput_fbf.jpgfullsizeoutput_fc0.jpgfullsizeoutput_fbd.jpg
    Kerry
    62 Tr3b TSF 198
    frame off restoration started
  5. #165
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,091
    Thanks Thanks Given
    14
    62
    Thanked in
    Perfect. Thank you.
    I saw the clip on the angled frame member and thought the line may use it but was not sure where it ran. I did not take this TR apart so no photos to go by.
    What point are you on your project?
    David
  6. #166
    Join Date
    Dec 2015
    Location
    Moseley, VA
    Posts
    35
    Thanks Thanks Given
    Thanked in
    David,
    I have many of the same areas of bodywork to do as you have. Although I do not have all the poor PO welding to deal with. I have welded in new inner sills and floors. Need to start the fabrication of repairs to the dog legs, rear inner fenders at the dog legs, front bulkhead at the floor and the edges of the front inner wings where the wings attach. I took time off from bodywork and tackled the transmission which is about done. The trans top cover turns out to be more work than the gears, etc. Chassis has been glass beaded and painted in epoxy primer. Haven't looked at the engine except to know it is not seized. Thanks for the updates.
    Kerry
    62 Tr3b TSF 198
  7. #167
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,091
    Thanks Thanks Given
    14
    62
    Thanked in
    Sometimes it is good to have several lines of work going at one time if you have the room to do that. I find it helps to be able to swoop around if you get stuck waiting on parts or inspiration.
    I am getting ready to reunite the motor and transmission. First I want to replace the clutch release bearing. At that point I think I can mount it back in the frame.
    David
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
