MGB Fixed a miss!
Flash_Harry
Our '74 MGB GT had an intermittent miss on a 2+ hour drive to The Gathering in Dobson, NC. It missed all weekend, and still had the miss on the 1 & 1/2 hour drive home. Figured I would have to either do a tune-up or have an expert do it for me. Did replace the NGK plugs with a new set, still missing. Took off the distributor cap to check the points - they looked okay and seemed to be gapped about right. Put the cap back on but didn't drive it for a couple of days. Got a friend to agree to check it out. Drove it the day before and it ran like a fine watch. Next day drove it 40+ miles to friend's house, not a miss all the way there. He thinks the gap may be a couple of thousandths too wide, but 40+ miles back home with not a miss. Apparently all I had to do was threaten the car with an expert! D'oh! :playful:
Platinum
:lol:
Just as the ache goes away mysteriously, the day of the doctor's appointment.
Flash_Harry
Flash_Harry
Yep, we have had a bunch of cars that cured themselves on the way to the mechanic!
Sarastro
I have to tell you my story, although it's not automotive.
Waaaaaay back around 1970, when I was in college, I built a color TV from a kit for my parents. When I first turned it on, the screen wouldn't light up. I checked everything as well as I could, and all seemed in order, but still the %#$@!! thing wouldn't work.
Finally, I figured that I needed an oscilloscope to go further with it. I checked one out from the electronics labs at school, took it home, set it up on the workbench, turned on the TV to warm it up (vacuum tubes in those days!), and the screen lit up! The thing worked perfectly from then on.
Rational technogeek that I am, I still think the thing saw me coming with the oscilloscope, recognized that the game was up, and just gave in and started doing its job. Probably cars do the same thing.
Platinum
I'll agree, Steve. Grew up with that stuff. One incident, Mother had a Walkman that suddenly konked out. The Ol' Fella and I did a vivisection on it on the kitchen table but found nothing suspicious. Ohm'd out the off/on pot, checked that the drive belt and mechanicals were all in place, all good. Reassembled it and turned it on to find it worked fine... Mom asks: "What did you do to fix it?" "No clue. It just decided it shouldn't go on strike any more."
Lots of other parallel tales with similar mysterious "spontaneous healing" from coffee makers to cars. Weirdness. I've blamed much of it on neutrino bombardment. :smirk:
JPSmit
My (late) mothers cure for fixing the TV - a flat palm smack against he side of the set. Worked every time.
Funnily enough that was my mother's cure for fixing me too - worked every time.
Flash_Harry
Flash_Harry
Dang! I thought my mother was unusual - guess not.
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
F How is the fron valance on BT7 fixed to the car? Austin Healey 1
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
F How is the leading edge of the rear quater trim panel fixed on a AH BT7? Austin Healey 16
Gray_Cat Lotus Elan Fixed Head Coupe FS Malibu CA Lotus 3
Got_All_4 TR2/3/3A Door handle can this bee fixed Triumph 1
Healey Nut Can this be fixed ?? Austin Healey 24
P Fixed gas smell Triumph 0
nevets sputtering issue fixed...it was the timing Austin Healey 4
hondo402000 TR6 TR6 More issues fixed Triumph 3
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
drooartz I fixed something! MG 17
M Weeping fuel pump fixed Triumph 0
richberman Adjustable shock mounts or fixed? Austin Healey 16
Pythias Speedo ...... pffft..... fixed. Spridgets 3
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
martx-5 TR2/3/3A Fixed the tach on my TR3...Sort of Triumph 10
sparkydave Now what? [fixed!] Spridgets 12
H HS6 Fixed needle centering tips Triumph 1
T 1989 xj6 FIXED! Jaguar 2
mountainman TR2/3/3A TR3 Hard Steering!!!!!Fixed!!!! Triumph 4
healeyboz Intermittent problem finally fixed Spridgets 6
ModifiedBJ7 A-H Fixed-Head Coupe Austin Healey 20
zimmy fixed the gearbox?! bearings and bullets? Spridgets 4
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
Baz Vacuum advance fixed! Spridgets 9
RickB FIXED - Distributor removal 'emergency' [not] MG 39
RickB Distributor pull - 25D - ideas please? - FIXED! Spridgets 2
T Fixed Battery Leak-I hope Triumph 13
X Sagging door fixed MG 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
C Alternator is Fixed! Triumph 2
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
SCguy Get oil pressure gauge fixed or just find another Triumph 12
ncbugeye Can these be fixed without a complete repaint? Spridgets 11
Banjo Fixed my dads "clunk" MG 3
J Fuel Gauge fixed almost. Triumph 5
M Acceleration Fixed MG 1
sparkydave Just when you think it's fixed.... Spridgets 7
Scott_Hower DOT5 brake fluid leak FINALLY fixed ! MG 11
SCguy Overdrive Fixed! Triumph 3
7 booo ya!!!!! i fixed that baby. MG 5
Sherlock Wedge spotted at a car show... TR8 fixed-head-coupe Triumph 4
J 1958 xk150 fixed head jaguar coupe Jaguar 3
Kim de B MGB MGB leaks - fixed MG 5
MikeAH100M High Temp Engine Miss Austin Healey 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
