Fasteners
radibob
While replacing the rear shocks on my 67 Sprite I stripped one of the bolts.which attach the shock to the body. Where do you get replacement hardware for these cars?
tiiM5
Is there a list somewhere that informs the size and thread of the most popular fasteners used on the BE?
I'm thinking of the engine compartment for example, the bolts that hold down various plates and brackets, not to mention other conspicuous spots.
Some purist or concours list must exist somewhere?
Keith_M
Almost all the bolts on these cars are standard US/English (as opposed to metric) sizes. Most of the bolts are fine thread, but there are a few coarse thread ones. I use pretty much all grade 8 because it's not that much more expensive than grade 5.
Find a hardware store that has a good selection. I don't find that the big box hardware stores have enough selection, and they often offer things in prepackaged quantities. You need to find a hardware store that keeps the bolts, nuts, washers in little bins so you can buy as many or as few as you need. They're also cheaper that way. Ask around if you don't know of place in your area.
nomad
A good farm supply store will have what you need.
Kurt.
Gerard
Yes, in my Tech section under the "Specs" drop-down menu. I have several references for thread sizes, torque specs, etc.
https://gerardsgarage.com/Garage/tech.htm
chris57
We have a store called Fastenall. I think they are a chain. If they don't have it they can get it next day. American made grade 8. Not Chinese copies. The only bolt I've had to buy from Moss are the windshield frame to body. 5/16" x 24 Oval head Phillips. OK that's an odd one.
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
B McMaster Carr for bolts and fasteners Spridgets 8
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
R TR2/3/3A Baby Tenax Fasteners Triumph 18
R TR2/3/3A Baby Tenax fasteners Triumph 13
KVH TR4/4A Two Questions: Driveshaft and Brake Cylinder Fasteners Triumph 7
petnatcar Tenax fasteners Austin Healey 2
Rut Stuck fasteners Spridgets 1
Rut Stage 8 fasteners Spridgets 7
S TR2/3/3A Tenax Fasteners Triumph 4
Jeepster Tenex studs / top fasteners Austin Healey 5
MikeAH100M Alloy Valve Cover Fasteners Austin Healey 3
tlthorne Looking for a source for the fasteners for a XKE Jaguar 7
A TR2/3/3A Tr-3A Body fasteners for top, boot cover and side curtains. Triumph 2
D TR2/3/3A tr3 windshield Tenax fasteners Triumph 2
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
P Fasteners for Bugeye Spridgets 3
Flash_Harry British Tools & Fasteners, LLC MG 1
Lin re-zinc plating for fasteners Austin Healey 8
R Hood Dzus fasteners Triumph 6
M Removing Lift-the-Dot Fasteners Triumph 8
M Healey Fasteners Austin Healey 3
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
D Rear Fender Fasteners Austin Healey 3
RickB Tricks removing old tenax fasteners? Need 4 tall.. Spridgets 11
martx-5 TR2/3/3A TR3 Bonnet Dzus Fasteners Triumph 10
E TR6 TR6 Timing Cover Fasteners Triumph 7
northstar what fasteners Austin Healey 1
RickB Grill trim fasteners Spridgets 16
bash Engine fasteners Triumph 12
rlandrum TR2/3/3A TR3A Missing Fasteners Triumph 11
Z cockpit surround fasteners? Spridgets 3
Lin BT7 rear seat fasteners and install Austin Healey 7
Brooklands Lift the dot fasteners Restoration & Tools 8
Z Interior panel fasteners Spridgets 4
M body fasteners for tonneau cover Spridgets 5
T Proper TR Fasteners? Triumph 29
B Hood fasteners Spridgets 1
Lin BT7 rear seat fasteners Austin Healey 0
RedTR3 TR2/3/3A Dzus Bonnet Fasteners on TR3 Triumph 3
P Fasteners Triumph 14
I Stainless Steel Fasteners? Triumph 10
Lin Rear Wing [fender] fasteners Austin Healey 1
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
K British fasteners Restoration & Tools 17
H Headlight Rim Fasteners Austin Healey 4
racing girl Fasteners, yet again! Restoration & Tools 6
G Fasteners Restoration & Tools 5
