TR2/3/3A The next stage of reassembly
DavidApp
Getting ahead of myself here but I wanted to ask what others had done to support the frame/Motor and transmission assembly at a good working height to work on the body.
At the moment the frame is on saw horses but I am sure they would not hold the combined weight of the motor etc. and I think it would be too high.
I need to redo some of the body work the PO did as the driver side door will not fit. I think when he replaced the floor and inner sill he did not check the gap before welding it in place.
Am thinking of building a lower stronger saw horse arrangement.
David
Popeye
Bronze
I've done two things. One, support the car on some crossed 2x4's, see image below. This makes the car overall high enough to work on while sitting on a rolling stool. Secondly, I have built some sawhorses to hold the body (without frame) high enough that the sill is roughly at chest height. Any body work that is not critical from an alignment perspective I will do on the saw horses. For example small patch panels, or removal of a rusted floor. Work is much easier when I can stand straight. Body work where alignment of the body/frame is critical - e.g. welding in the floors, I will do with the tub and frame bolted together. Typically I weld enough to create a rigid structure, then lift to the more convenient height to complete the rest of the welding / grinding / aesthetically pleasing finished joint.
DavidApp
Thank you for the feedback.
The car looks great Luke. I presume that those are the heavy duty stands.
luke44
Harbor Freight iirc, very inexpensive, something like $35.00-$40.00 per pair, rated for 6 tons each.
DavidApp
Thinking the same about the garage floors.
I need to do some cleaning before I post photos.
I had looked at the Harbor Freight stands. In fact I have one of the smaller ones.
DornTRoriginal
David
David I had similar thoughts as others, Jack stands are the most cost effective, I got 3 ton stands for about $30 a pair, the good thing is they store pretty well and can be reused. I also use wheel dollies that allow me to move the car around the garage but do not provide the lift you need for some jobs. If you can afford a four post lift and your work space will allow it, interior height is the critical factor that's what I would do. There are a number on the market and the price range is $2,500 and up. I'm saving up for one if I can ever stop buying new parts! www.ShopEquipmentLift.com
https://www.directlift.com/ceilingCalc.aspx Ceiling calculator
https://www.youtube.com/watch?v=aQwrGaMb9cE Company that makes the lift Dover Corp / VSG
https://www.youtube.com/watch?v=oJ5te_RHWH8 Parts Department Video
https://www.youtube.com/watch?v=JNcqmy2sAqA Installation Video
DavidApp
Looking around the shop I found that I had material to hand to make my stands. Some of boards were saved from our deck. Recycled wood.
Very solid and only took a couple of hours to make.
J Next Thread? FORUM Navigation Questions 1
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
apbos The next rabbit hole. Help ID the chassis. Racing 27
drooartz MGB Front suspension rebuild is next MG 57
R General TR Emergency hot wire - because you never know whats next Triumph 2
S TR2/3/3A wood next to the door on a tr3 Triumph 4
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
M Next job[s] on Otto - thoughts? Spridgets 35
H Anyone going to the Fall AACA Meet and Flea Market over the next several Days? Austin Healey 2
D TR6 Researching potential next project car - Looking into TR6 Triumph 5
PC next tool hunt Restoration & Tools 0
AH100M My 100 is being auctioned in Ft. Lauderdale next Saturday March 28th Austin Healey 44
J TR2/3/3A Body is on frame, what's next? Triumph 1
R TR4/4A Ok - Now I Tore the Dash Apart - What's Next? Triumph 11
aeronca65t NJ Historics -next weekend Racing 2
RickB Next project: Arkley conversion on a 73 Midget Spridgets 8
A TR4/4A My next restoration with a little help from "Fantom Works" Triumph 2
Stewart MGB-GT Next Project 1967 GT MG 139
BlueMax Next Big Step Spridgets 15
regularman when is the next spridget gathering? Its been too long folks :D Spridgets 20
drambuie Pit crews of the 1938 Grand Prix's [Next time i will jump out and refuel myself] Austin Healey 1
Stewart Next Project MG 13
Michael Oritt PVGP next two weekends Racing 17
JPSmit Next question - where's Billy Spridgets 1
JPSmit Make next year's Memorial Day truly memorable! Other Cars 7
aeronca65t Next two weekends Racing 1
RickB Going to Las Vegas next week, any car attractions? Spridgets 11
JPSmit Next question - Vimeo FORUM Navigation Questions 1
M Where would you buy your next fuel tank? Austin Healey 6
vette Next Question on Rear Springs Mounting Austin Healey 2
B Generator not working, took apart, what's next? Austin Healey 33
HealeyRick My Next Modified Austin Healey 17
Bob Claffie Wedge Next car TR8 ? Triumph 19
Got_All_4 Who's going to The Roadster Factory Party Next Wk? Triumph 10
drooartz Back in business, hopefully next week! MG 16
Tr3aguy TR2/3/3A Next step to try to start TR3 Triumph 3
K TR2/3/3A Next hottest plug from NGK BP6HS on a TR3? Triumph 4
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
texas_bugeye Look what parked next to my baby benz! Spotted 0
B Another NODoody next Saturday Spridgets 5
vping T-Series Finally my next project - A 1952 TD MG 4
QuickSilver Rats Next Wiring MG 6
T OT - my next project Triumph 22
G On to the next step! MG 3
JPSmit My Next Project Other Cars 27
T Found my next ride, and just in time too Triumph 24
B Beaulieu Autojumble next weekend MG 9
John_Worthington Next steps Jaguar 12
drooartz Progress: tank in, engine is next! Spridgets 10
6 next problem Triumph 11
