Oil recycling ad
dklawson
I like it. The commercial is short, informative, and to the point.
Our city and county landfills accept drain oil. However, I typically take mine to the large parts store franchises as they also collect it... and they are closer. In 2009, NC (where I live) passed an ordinance that you were not supposed to throw used oil filters in the trash. Now the parts stores that collect used oil also collect the filters. It is a very handy.
nomad
Wonder what they do with the filters. I used to drain them well and burn them in my shop heating stove. All my used oil goes to my local John Deere dealer who uses it to heat his shop.
Kurt.
PAUL161
Greyhound bus co. has been recycling motor oil for years due to the tremendous cost of replacing with new. They even claimed that the recycled oil has better sticking qualities to moving parts, something to do with the re arranging of the atoms, or something like that . Only thing that happens to oil is it gets dirty before filtering and looses it's cleaning chemicals, which they put back. PJ
SaxMan
Nice ad. Wish my oil changes were that nice and neat. Looks like you could eat off the oil container.
oil coming out of the engine didn't look too bad either.
bugedd
bugedd
The oil container was new, the one I use is 20 years old and is pretty hammered. Thanks for the compliments, we thought it turned out ok. Much better than the previous version which had a fellow that clearly didn't know which way to turn a wrench talking to his child about changing the oil on his minivan in his sterile garage that looks like he just moved it. Not exactly believable.
nomad
When I was in the Navy we would send the nastiest looking old oil down to be centrifuged and it would come back looking like you just poured it out of a new quart container. The centrifuge was a simple machine and i considered getting a surplus one to start a small sideline. Never did. I always thought that Valvoline was recycled oil?
Nice vid Ed
Kurt.
dklawson
I think a couple of the big name oil brands do offer a recycled or recycle blended oil.
We used to have an oil reprocessing center around here run by NC State University. It closed many years ago. I'm not sure why it didn't prove to be viable. I think they had a decent market for their product in the various motor fleets around the state.
I decided to Google the topic or oil recycling and found the article linked below on the Scientific American web site. I'd like to think it is a bit more reliable and accurate than most sources on the internet.
https://www.scientificamerican.com/article/can-oil-be-recycled/
nomad
Interesting article, Doug. One of the reasons I didn't pursue the centrifuge is that I studied up on some of that and realized that adding back some of the additives would be necessary to make a good product. The centrifuge did a great job of removing water from the oil. Perhaps not as much as the re-refining process but enough so that you wouldn't think there was any in it.
Kurt.
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
L Oil Pumps Austin Healey 6
