Results 1 to 10 of 10
Thread: Datsun 210 Trans Question
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Knight bugedd's Avatar
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I have the Datsun 5 speed in my bugeye and after significant drives, I get a slapping noise when letting off the throttle. It sounds like the shifter hitting the surround and can be felt in the body of the car when putting my hand on it. I took off the surround and drove it....still had it. I looked in the trans tunnel for anything that could be hitting with a flashlight and mirror, and couldn't see anything. Is there something in the trans shifter area that could be worn and cause this? It seems to only do it in 4th and 5th gears.
    1960 Bugeye AN5L43788, 1275, Datsun 5 speed, bunches of fun goodies.
  2. #2
    Join Date
    May 2013
    Location
    Bonita, california
    Posts
    675
    Blog Entries
    2
    Thanks Thanks Given
    2
    Thanked in
    Re: Datsun 210 Trans Question
    I have the Datsun 5 speed also and I have had no problems like you have stated.
    The person that could probably answer your question is Bill M.
  3. #3
    Jedi Warrior 58Custom's Avatar
    Join Date
    Apr 2008
    Location
    Canyon Country, CA.
    Posts
    524
    Thanks Thanks Given
    Thanked in
    One thing to look for is the clearance between the yoke and the trans tunnel. Clearance here can be slim to none and a few folks have had interference issues, myself included. If this turns out to be your problem a few minutes of work with a pry bar (or a selection of real and/or improvised pry bars) will allow you to revise the contour of the sheet metal in the affected area and will eliminate the issue.
    Causes of interference vary, as tunnel shape and abuse to the tunnel over time is individual vehicle-specific. Mine was kinda squashed down just a bit for some reason.
    ____________________
    1969 MG Midget, A15, 5 speed
  4. #4
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    615
    Thanks Thanks Given
    3
    Thanked in
    Speedo cable routing?
    Door handles,Bootlid,Glovebox all fads
    59 sprite
  5. #5
    Join Date
    Apr 2006
    Location
    Santee, Ca
    Posts
    3,031
    Thanks Thanks Given
    Thanked in
    Ed
    Do you have a "right-angle" speedometer cable adapter on your trans?
    That might be an issue (or the speedo cable slapping the trans tunnel)
    BillM
    '69 Sprite Mk IV
    '60 MGA
    '65 Midget
  6. #6
    Jedi Knight Pythias's Avatar
    Join Date
    Apr 2008
    Location
    Kelso, Washington
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    When Paul A. did my car and the end of the yoke hit the tranny tunnel ...... with was still up on the jackstands, with the engine running at idle, let out the clutch in first gear and ..... throw a broomstick up the tunnel. the yoke catches the stick and beats the tunnel out.. there's no other way to access the area of interference.
    That was Paul's solution for years... .. Gerard I think had a 1/4" thick spacer to put at the pumpkin end of the yoke to move the other end further up the tunnel so that this "fix" isn't needed?....
    Bill L.
    1966 Sprite MK III - "the red thing"
    HAN8L49403
    President, Pacific Northwest Chapter,
    Sprite Midget Club, USA
    (Excepting Greater Seattle)
  7. #7
    Senior Member 1974MGMidget's Avatar
    Join Date
    Dec 2009
    Location
    Grayson, GA
    Posts
    69
    Thanks Thanks Given
    Thanked in
    If you have a grease nipple in the U-joint, it could be hitting the tunnel, although if only in 4th and 5th gear, may not be your problem.
  8. #8
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    I'll have to put it in the air this weekend and have a second look. Pretty hard to see in the tunnel for clearance, maybe I can get a better view from under the car. Thanks for the advice!
  9. #9
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    615
    Thanks Thanks Given
    3
    Thanked in
    Quote Originally Posted by Pythias View Post
    Lol
    maybe we need a WIKI on this holly smokes
    59 sprite
  10. #10
    Join Date
    Apr 2008
    Location
    Kelso, Washington
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by SD Bugeye View Post
    Lol
    Oh yeah,.. it took a few tries to time it just right to catch the stick at just the right spot. As in "Let out the clutch ... NOW!" It came out all splintered up after we hit the "sweet spot".
    Bill L.
    HAN8L49403
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
