Modifying stock shift surround for Datsun 5 speed
Loren C
I've been told that by shortening the stock metal shift surround it can be made to work with the Datsun transmission. What I don't know is how much it needs to be shortened to prevent it from interfering. Has anyone done this successfully and/or know how much it has to be shortened?
nomad
Yes, I've done it but I also modified the shift lever by cutting it and rewelding the lever on the side of the cut off. This gets the lever to a more central position. I then cut all the straight side off the stock hump and rewelded that. As I remembered about an inch and a half. As i think about it now though, i scrapped the idea of running the stock rubber boot because I though it was contributing to popping the gear shift lever out of gear in one gear and now run the later lever gaitor and a homemade seal that seals out drafts right at the pivot of the lever.
Kurt.
Rut
I'll wait to cut and weld mine until the transmission is in, but using an unmodified 'top hat' looks very doable.
Rut
I cut about 3/4" out of mine and carefully re-welded the shifter to center it. It still pops the rubber gaiter out of place from time to time. I'm not happy with how it turned out.
SD Bugeye
I would wait before you cut a thing until you have the 210 box in place and have shortened the shifter.
in my case I followed the instruction on cutting down and offsetting the Datsun sifter and marrying the stock one .
mine fits perfect with surround boot and shifts perfect with no modifications to the boot.
heres the shifter in neutral on my car.
SD Bugeye
Rut
Totally doable if you want stock look as I did.
smaceng
It all depends on how the cut and rewelded shifter is positioned in the sheet metal cut out. Wait until you get everything else in the install is done, and check the fit. Most likely the shifter will hit the sheet metal. Open it up accordingly....and it will be good......60Frog is happy!
Scott in CA
nomad
Well the reason to cut that cover down is to keep from putting so much pressure on the shift lever. When modified it's not all that noticeable.
SD BE, I'm amazed that you don't have trouble with the stiff stock gaitor pushing the shift lever out of gear. The Datsun shift lever pivots much lower than stock.
BTW, I think I removed about the same as Trevor....memory.
Kurt.
Billm
I agree with everyone above- when you are welding it back together the total length of the shifter should be 7 to 8" long.
There are many different shifters that go into the 210 trans and they all start out different lengths (I have had MANY of them) but they all need to be cut down to about 8" long for the Spridget, both Bugeye and later need the same length.
BillM
Billm
--also-
Bill Loeb had the actual shifter surround can shortened by about 1" which lowered the rubber gater and made everything work much better. He will probably post a picture here soon
BillM
L
Loren C
--also-
BillM
That's what I was talking about. Shortening the stick doesn't do anything to fix the interference unless it's also offset.
SD Bugeye
Kurt.
No issues one finger shifting here .
nomad
I guess ya'll are talking specifically about a BE, right?
BMC and Leyland kept the domed cover though the mid 60's at least. Had a 68 parts car and that may have had it as well. I believe hey kept it only covered it with the naugahyde gaitor even later.
Kurt.
gfholl
I also increased the diameter of the hole in the shifter surround, but used a Big Healey center shift rubber gater.
Gerard
Kurt.
The change to a gaiter was around mid to late 1972. I had a mid-year 72 that still had the can.
I thought it started with the face lift cars in 1970. I had a 69' parts car with the metal can, but my '70 had the vinyl boot. But these cars had already passed through several owners before I gained possession.
drooartz Modifying castle nut Restoration & Tools 3
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
G Modifying the triple intake choke/throttle setup Triumph 18
tony barnhill Modifying Leaf Springs - Part 2 MG 6
tony barnhill Modifying Leaf Springs MG 26
tony barnhill MGB Modifying an MGB Differential MG 50
D Modifying the Jag V12 engine. Jaguar 3
waltesefalcon Spitfire race modifying a spitfire 1500 Triumph 16
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
