Results 1 to 19 of 19
Thread: Facet pump died
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Knight bugedd's Avatar
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Facet pump died
    Took the car out for the first time in a while, thing drove okay for a bit, then sputtered, coughed, and died. Then it fired up, drove a bit, did the same thing. I made it home and watched the fuel pressure gauge, and it slowly dropped from 2psi, then back up, so it looks like the Facet died. Is that common with the Facet pumps? If so, I'd like to change to something reliable.
    1960 Bugeye AN5L43788, 1275, Datsun 5 speed, bunches of fun goodies.
  2. #2
    Senior Member 1974MGMidget's Avatar
    Join Date
    Dec 2009
    Location
    Grayson, GA
    Posts
    69
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    Seems like Facets are generally reliable, but even the most reliable pumps will die at some point. If you decide that it is, in fact, the pump, why not an SU pump rebuilt by Dave DuBois? I've been running one for several years now with no problem (yet!). https://userwebs.donobi.net/sufuelpumps/
    Before getting the rebuilt pump, I had a minor incident that involved changing a fuel pump in an Illinois corn field. After that, I added a back up Facet in addition to the rebuilt SU. So far, haven't had to use it, but I do check it every once in a while. There seem to be several choices these days, and I'm sure you'll get some feedback on the others, like Airtex, etc. Good luck.
  3. #3
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Re: Facet pump died
    I'm wondering if your fuel filter is plugged or you have an air leak before the pump. Facet's are noisy but fairly reliable. I did have one that would lean out under hard acceleration though.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  4. #4
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    I found a facet in stock local, so I put it in with a new filter. Its much louder than the previous one which I find odd.
  5. #5
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    Re: Facet pump died
    When installing the metal cube Facet pumps, pay attention to their request that it be mounted at a 45 degree angle. The following is hearsay from another LBC owner but I have no reason to doubt it. Apparently the steel slug moved by the electromagnet in the Facet pump is prone to sticking if mounted horizontally or vertically but lasts longer when mounted as described on the installation instructions.
    I have spare Facet pumps rigged with alligator clips and about 3 feet of fuel line in the boot of the Mini and our GT6. It won't take me long to bypass a dead pump and clip one of these in place should I ever have to.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  6. #6
    Jedi Knight Bob Claffie's Avatar
    Join Date
    Feb 2003
    Location
    Dalton Mass
    Posts
    948
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    In my MGB I added a BARR brand pump (about $15) in line with the original pump and switched separately. Both pumps are flow through pumps so if either one quits the other will function correctly. Bob C
    Thank goodness the MG is finally gone, replaced by another Corvette
  7. #7
    Jedi Knight Pythias's Avatar
    Join Date
    Apr 2008
    Location
    Kelso, Washington
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    I've had my facet in for about 15 years, but I have a brand new Airtex sitting in wait.
    Bill L.
    1966 Sprite MK III - "the red thing"
    HAN8L49403
    President, Pacific Northwest Chapter,
    Sprite Midget Club, USA
    (Excepting Greater Seattle)
  8. #8
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    Had an Airtex in the last car, was nice and quiet. May change to that at some point to quiet things down. Weather is too good right now to order something and be without the car.
  9. #9
    Yoda tomshobby's Avatar
    Join Date
    Apr 2006
    Location
    Windsor, Wisconsin
    Posts
    3,879
    Thanks Thanks Given
    2
    Thanked in
    Re: Facet pump died
    I agree with checking out Dave DuBois. I followed his recommendation for a back-up pump https://userwebs.donobi.net/sufuelpu..._Fuel_Pump.pdf
    Tom
    76 TR6
    74 Midget
    www.madbrits.org/
    www.mg3club.org/
  10. #10
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    615
    Thanks Thanks Given
    3
    Thanked in
    Re: Facet pump died
    Facets are excellent pumps. But debris of any kind in fuel will kill them.
    if scale - rust get into them it can pound into the ball seat and they can't hold pressure.
    i have run one for years with a large high surface area filter prior to the pump.
    Door handles,Bootlid,Glovebox all fads
    59 sprite
  11. #11
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Re: Facet pump died
    I've got a pile of SU pumps that I'll never get around to working on. I'm sure some of them would be good with nothing more than cleaning the points. I'm wondering if anyone offers a rebuild service and might want them.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
  12. #12
    Join Date
    Mar 2005
    Location
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    Re: Facet pump died
    Dave will rebuild them for you. He may even offer to buy them as cores.
    Doug L.
    '67 Triumph GT6 Mk1
  13. #13
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Re: Facet pump died
    Quote Originally Posted by dklawson View Post
    Well, i don't think I want to dig through the snow to get to them right now but how do I get hold of Dave Dubois?
    65,66 Midget
    57 Berkeley, MGA
  14. #14
    Join Date
    Nov 2005
    Location
    Utah
    Posts
    648
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    I talked to Dave a couple of weeks ago and he is laid up with a bad shoulder for a while but is accepting work for when he is able. His phone number is 360-479-0462 and he lives in Bremerton, Wa. Have a good day!
    John
  15. #15
    Join Date
    Apr 2006
    Location
    Windsor, Wisconsin
    Posts
    3,879
    Thanks Thanks Given
    2
    Thanked in
    Re: Facet pump died
    I mounted a Facet pump as a back-up. I also used rubber standoffs and can hardly hear it run.
    Tom
    76 TR6
    74 Midget
    www.madbrits.org/
    www.mg3club.org/
  16. #16
    Join Date
    Dec 2009
    Location
    Grayson, GA
    Posts
    69
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    Here is Dave's website, some good information there: https://userwebs.donobi.net/sufuelpumps/
    Also, an MGB transmission mount (413-050) makes a good Facet mount. The two studs match the mounting holes in the pump and there is only one stud for mounting, if you already have a suitable hole somewhere. But, it may not be as compliant as the standoffs.
  17. #17
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Re: Facet pump died
    Thanks for the info on Dave....i'll make a note of it.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
  18. #18
    Join Date
    Apr 2006
    Location
    Santee, Ca
    Posts
    3,031
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    Ed
    Check/fix the ground on the Facet and I will bet that it will run for years more
    BillM
    '69 Sprite Mk IV
    '60 MGA
    '65 Midget
  19. #19
    Join Date
    Aug 2010
    Location
    Chico, CA
    Posts
    1,186
    Thanks Thanks Given
    Thanked in
    Re: Facet pump died
    I already replaced it, but the ground looked good. Maybe I'll dig it out of the recycling and hang on to it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
