John_Progess
My 61 Sprite was totally disassembled when I got it and it came with a 10CCDaH13730 motor. There is no provision on the block for a mechanical fuel pump so where were the electrical pumps mounted in these cars. The fuel line was attached to the car and it is continuous all the way from the fuel tank to the engine bay. My other LBC's have their electrical pumps mounted near the fuel tank. I don't know if this engine was ever used in the car. In my parts there is a 7 1/4" diameter clutch. I have a rib case and smooth case trannys. Is this the clutch I should use if I want to use the rib case with the 10 CC motor? Thanks for your help and have a good day!
John
John
