TR2/3/3A very high idle, timing perfect
2billydavies
hi everyone. something to swing by everyone, maybe someone has some guesses.
My TR3a has a really, really high idle. Unfortunately I cannot tell you the RPM's as that gauge is broken (sending it somewhere to be refurb'd after the New Year). But it's definitely running very high.
The timing is perfect. Everyone on this forum helped me with that about a month or so again... it's perfect. I have both carbs sync'd. I believe the gas mixture is right where it needs to be.
Any ideas? If I adjust the timing to bring it "down" a little bit, the car runs like garbage. No power, pinging and ticking everywhere. When i have the timing set perfect, it runs great. But the idle is so high.
One thing I did notice though... the butterflies on each carb. They are synced, but both of the adjustment screws are completely out. If I screw them in even just a little bit, the idle goes through the roof. So I have them both backed all the way out.
Any other adjustment ideas I might be missing? The car runs perfectly. Great power, sounds awesome... super happy about it. Just a very high idle. I feel like I might be missing something, but there's only so much I can think of.
Anyways... thanks a ton for a year's worth of help with my rebuild. No way I would have gotten it done without this forum. Hope everyone has an awesome New Year!
trglory
Look down the throat of the carbs to make sure the butterflies are closed when the engine is off. If not, you may have to adjust your linkage to make it happen.
TR3driver
Great Pumpkin - R.I.P
I would try disconnecting the linkage at the front carb, first. If that lets it idle down, then you know the linkage is misadjusted or binding. Then try snapping the throttle shut (open it and let it slam shut). If that makes it idle down, you're probably looking at a worn throttle shaft allowing the butterflies to drag against the bottom of the throat. If it still idles high, I'd look for a vacuum leak next. (One way is to spray carb cleaner or WD40 around likely sites. If the engine note changes, you've found a leak.)
If all else fails, someone may not have gotten the throttle plates properly centered to the bore, or installed backwards. If that is the case, you'll have to remove the carbs to fix it (and should replace the throttle plate screws).
titanic
I second Randall's suggestion of checking the centering of the throttle disc. Also, if the throttle shafts have been replaced, it is possible that the hole for the throttle top was not drilled in the correct spot. This would prevent the throttle disc from completely closing.
Berry
Kleykamp
You mention the idle adjustment on each carb, but you didn't mention the fast idle screw for the choke. Check it to make sure it's not in too far.
sp53
It kinda depends on how fast of idle 1200---1500? Do you have a tune up tach on a dwell meter? I usually suspect a vacuum leak like an intake manifold gasket or throttle shafts and yes perhaps the idle screw on the choke is set high. The best timing is set by driving and I find that the timing is usually a little advanced, so for me when I turn the timing back the engines does bog down. I find a balance between the timing marks and a good idle. Too much dwell will make the engine idle a little fast also. In my experience if you can get an idle of 800, you are doing well.
Jake49
Good suggestions so far.... I was having a similar problem and finally solved it by adjusting the float valve on one of the carbs.
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Bayless The very simple rotisserie Spridgets 3
G TR4/4A Flasher Unit...VERY hot Triumph 10
R Very Difficult cold weather starting problems! Austin Healey 21
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
drambuie The nasty boy Healey version may very well be more true to the original intent! Austin Healey 14
andrea Very strange austin healey 3.9 Austin Healey 5
P gearbox shifts very badly Austin Healey 7
T TR2/3/3A Air dam seems to be working very well Triumph 5
W Very respectable restoration Spridgets 9
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
tinman58 TR5/TR250 Very stiff rear end Triumph 27
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
drooartz MGB Sometimes I'm very proud of my work... MG 6
John Turney UPDATE: Up-date on a Very Expensive Healey Austin Healey 8
D BT7 Hard top back window that is very cloudy Austin Healey 5
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
tr7andtvr Very Disappointed with Lotus at Indy 500 Lotus 13
swift6 A very wild morning drive... Triumph 34
C One very cool Allard Other British Cars 2
C A very pretty little Elva MkVII Racing 1
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
JPSmit Very cool rat rod! Other Cars 3
C The Story of a Very Special Jaguar Racecar Jaguar 2
JPSmit Need a MOWOG and very confused Spridgets 13
C Very nice Triumph-Powered TVR 2200 Special Racing 9
J Anyone interested in very original 1958 Bugeye? Spridgets 1
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
V Very nice Jensen Healey on eBay Other British Cars 10
14dna Very Sad Sight Spotted 0
T very early gear wear Triumph 8
JPSmit very scary engine noise Spridgets 37
