TR2/3/3A Transmission not going in
Sumton
this car has been undergoing restoration for years. finally got it running and driving a few months ago, and ran into numerous problems. note: i had mistakenly paid somebody to do most of the work, and he decided he didn't want to finish it. most likely, he did such a lousy job he didn't want to be responsible for fixing the crap he did wrong. anyway, the transmission leaked so badly we had to pull it after putting about 7 miles on it. there was also a shifting problem, and we had to pull it to be sure there wasn't a problem with the clutch fork. anyway, we have tried twice to put it back in but can't get it home. it goes in far enough that it sits on the three top studs, but we can't get it any farther in.
i will also note that the alignment tool is hard to insert all the way too, like the tolerances are too tight.
thoughts/recommendations/direction?
thanks!
TR3driver
Great Pumpkin - R.I.P
Did you check that the clutch friction plate fits onto the gearbox input shaft? Almost sounds like you've got a size mismatch somehow; the last alignment tool I bought was so loose that it was useless.
Another possibility might be a damaged pilot bearing.
If it was bolted up tight before you pulled out then it should go back. The angle of trans to motor may be off. Try raising Engine up a little. If you moved clutch while trans was out then that alignment is off as well. If trans is in far enough for the three stud to hold trans in place, take a piece of wood (2x4) to rear of trans and hold against tail flange and hit it with BFH, trans in gear, turn tail shaft and hit again. Repeat until trans slides into place.
Marv
Chuck Murphy
I just had the same problem. What happened to me was that the clutch disk slipped a little as I withdrew the tranny (do not know why - tranny nose hit disk on way out??). I had to use my alignment tool to center the clutch disk again. My alignment tool does not fit all the way into the clutch, but it must slide in and out VERY EASILY. You might try the alignment tool again and loosen and then retighten the 6 (or is it 8?) clutch plate bolts again. Chuck
tdskip
The other tip that can be a big help is to use several longer same thread bolts to help guide the transmission back into place.
Go to Ace hardware or similar and get three 3 or 4 inch bolts and start threading those in. This makes alignment so so so much easier.
Please keep is posted on how you are doing.
karls59tr
Another way is to cut the heads off two same thread bolts,file a notch in the non threaded side to fit a screwdriver,screw these bolts into the mounting holes about 2/3rds up on the flange. This setup will act to take the weight and as guide to slide the gearbox on. The first time I mounted a TR3 gearbox back in the day I must have fought that thing for hours:encouragement:.
S
Sumton
thank you all for the many ideas. i'll go after it again today. I did not mention in my first post that i removed the clutch to inspect it. so likely there is an alignment issue.
thank you again and happy holidays!
chuck69ss
This is what I was going to suggest. It also helps reduce any accidental torque on the shaft from the transmission weight hanging on it. Learned the hard way a few years ago..
S
Sumton
just a quick note - i hurt my shoulder but hope to be back at it this sunday and monday. i will let you know
S
Sumton
we are getting closer but cannot get it all the way in. i'm going to try some bolts around to see if i can use those to pull it all the way in. it feels like the shaft is in, and catching. we just cannot close that final inch.
TR3driver
Well, good luck with that. I think you're making a mistake. The input shaft HAS to be an easy, sliding fit in both the pilot bearing and the clutch plate. If not, the clutch isn't going to work right even if you do manage to force it together. And if the shaft is caught on the splines, or on the pilot bearing, then something is going to break before it goes together.
crash21
I learned this the hard way. I replaced the clutch, t/o bearing and pp as well as the pilot bushing on a 80's pickup truck. I realize it isn't a LBC but the principle is the same. I fought for hours to get that shaft to slide into position. Tried it, put it down, check everything out, tried it, put it down, check alignment etc. Over and over.
I got mad at it and used the bolts to pull it up into position. When I started the engine it sounded terrible and the clutch wouldn't disengage at all.
I had to take the whole thing apart again and I found I had burred the pilot bushing and then cracked it .
It should go in fairly easily. If not you have got something out of alignment.
Good luck. Just walk away from it if you have to and come back to fight with it another day.
donbmw
I have had my transmission out twice since my car has been back on the road. The first going back in even with someone help it did not go easy. We fought it and fianlly got the right alinement and it slide right in. Second time I did it by my self even though I had help when need. Had engine supported with a jack when trans was removed. Going back I used a floor jack to support the trans at what looked to be the right position. Saw that the engine and trans alinement was way off. Jacked engine until the gap between them looked the same. Pushed jack and trans forward and it slipped right in. Had may be 30 min. Where over an hour fighting it before.
sp53
Do you have the correct pilot shaft bushing? I suggest starting over and remove the clutch and make sure the disc is facing the right way around and that it slides on the splines easily and the pilot bushing is not too tight. I usually buff up the trany splines with a wire brush and buff up the splines on the disc also to make everything slides. I have also put a very small amount of anti- sezz on the splines, but do that at your own risk because it could get on the clutch.
Like mentioned before the trans and engine need to be on the exact same plane. Sometimes that requires undoing the exhaust to let engine drop down in the back.
CJD
It's the clutch disc. Everyone goes through this situation...once...and realizes how important it is to get the disc aligned right.
If you use the bolts to cinch it up when it doesn't slide in easily...you deserve the damage that will ensue.
I repeat...it's always the clutch disc.
Mkutz
I recall having a similar problem and using two big C-Clamps on each side to pull it all together. Worked for me. Good Luck!
bnw
50 years ago (WOW) I cracked the bell housing doing it that way. On our cars, the bell housing IS the gearbox. Don't do it!
S
Sumton
finally found the time to revisit this. thanks to the advice from you guys - went out and bought some 1/4" grade 8 bolts for the holes and a larger bolt for the starter area. used those to pull the tranny that last inch. its in!!!! so now all i have to do is put the whole interior back in!
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
PAUL161 T-Series 5 Speed Transmission MG 85
PAUL161 T-Series Replacing Transmission MG 3
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
R TR2/3/3A Transmission Service TR-2 Triumph 58
Spock TR6 Transmission Plug Triumph 4
